Anybody mount 4 point harnesses in their CJ7? - JeepForum.com
post #1 of 24 Old 02-17-2010, 08:22 PM Thread Starter
Daladim
1982 CJ7
I'm looking at putting 4 point harnesses in my CJ7, and I'm trying to figure out how to mount them. I'm eyeballing these right now:
Corbeau Racing Harness 3 4 Point Harness Safety Belts Race Harness 5 Point Race Retractable Belts
They come in either bolt in or snap in, and I'm not sure which I should go with. My seats, once they get upholstered, will have slots for the upper straps built into them, so I will have gotten that far with the installation. But where do I bolt them down at?
I would think that simply using the seat riser bolts on the back of the seats would be unwise, even if it would make mounting easier. I would also assume that I need to have some kind of support to where the bolts will mount at.
Anybody have some pictures of how to mount these, or some insight as to how I would go about doing such a modification?
Thanks much!
Daladim is offline
post #2 of 24 Old 02-17-2010, 08:29 PM
ReconRabbit
1983 CJ7
I have five points in my CJ7 but have a front cage so not sure if my mounting will help but here's a pic for you.
I can probably load up some more pics if you need, just let me know.
If your Jeeps not leaking it's out of fluids.
ReconRabbit is offline
post #3 of 24 Old 02-17-2010, 08:34 PM
ReconRabbit
1983 CJ7
Found the rest, here ya go!
post #4 of 24 Old 02-17-2010, 08:38 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Is it street legal to run a 4/5 point harness?
Sorry for the thread jack.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #5 of 24 Old 02-17-2010, 08:43 PM Thread Starter
Daladim
1982 CJ7
Thanks for the pic, but that's not really gonna help me. My interior is bone stock except for the seats, which are out of a Fiero. I don't intend on welding in a cage just to get the seatbelts mounted. Of course the cage will come eventually, but I plan on going with a Rock Hard Bolt -in cage meself.
My only option is to mount these to the floor pan somewhere. Do I need to weld in reinforcements, or can I just plant some bolts into the pan? The reason I am going this direction is that the PO replaced the pan on the passenger side, and didn't get the seatbelt hole replaced on the outside of the seat. So I don't have a passenger side belt at all. I figure if I got to do seatbelt work, why not upgrade them as well?
Daladim is offline
post #6 of 24 Old 02-17-2010, 08:47 PM
ReconRabbit
1983 CJ7
The best mounting of the shoulder harness is a bar like I have on the top. The lap belts could (and I had them) mount in the factory belt locations. The factory mounts have a nut welded on the back side with a reinforcement plate in the body.
post #7 of 24 Old 02-17-2010, 08:49 PM Thread Starter
Daladim
1982 CJ7
Near as I can tell it woul be street legal. And why not? It is a safety belt...
I just want to make sure mine is safe. I think using the seat mounts would run the risk of tearing the seats out of the floor in an accident, so I need to confirm this and or learn how to mount them into the floor properly.
Daladim is offline
post #8 of 24 Old 02-17-2010, 08:52 PM Thread Starter
Daladim
1982 CJ7
So then if I buy these harnesses, I'm gonna need to do some fabrication in order to use them, right?
Daladim is offline
post #9 of 24 Old 02-17-2010, 09:24 PM
CJ Chet
I used one of these. It's a bolt-on piece and works very well. I have the snap-in belts since I only use them when wheeling.
Rock Hard 4x4 Parts - Shopping Cart
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #10 of 24 Old 02-17-2010, 09:30 PM Thread Starter
Daladim
1982 CJ7
That's nice, and will go well with my plans for this Jeep. I have actually been doing a bit more research since I posted this question. Guess I should have done so before asking the question. As it turns out, it looks like I am going to have to go this route. My original idea sounds like it is dangerous.
I'll have to forgo mounting these belts this summer, and just wait until I can afford to build the cage first. This means I'm gonna have to find somebody to fix the stock belt on the passenger side.
Have you got any pictures of how you mounted the belts to that cross bar from Rock Hard? And how does that bar effect the recline-ability of the seats? Is there much room between the seat and the bar at all?
Daladim is offline
post #11 of 24 Old 02-18-2010, 05:07 AM
Mike Romain
No it is Not street legal.
Those are 'racing' harnesses that don't allow you to do a proper shoulder check for lane changes so they cannot be used on the street.
Folks that have daily drivers need to leave the stock 3 point harnesses in for daily driving and then use the second set of 4 or 5 points for off road only.
Mike
Mike Romain is offline
post #12 of 24 Old 02-18-2010, 07:26 AM
GraKee99
Rapist Wit
GraKee99's Avatar
What if my rig only came with a 2 point? Should I just leave that in then or would the lower 2 straps of the 4 point be sufficient.
This is where I get confused because I am also told it is illegal to only a have a 2 point but that is the stock way it came. Some law that says vehicles past a certain year must have 3 points and I think my 76 meets that.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #13 of 24 Old 02-18-2010, 07:32 AM
Mike Romain
Everywhere I have lived, you were allowed to have what it came with stock, but you should check your local laws. If it only had lap belts like my 76 Chevy pickup did, that was legal.
I also see folks with both sets in for some reason, so that implies they just use one or the other.
Mike
post #14 of 24 Old 02-18-2010, 08:10 AM
GraKee99
Rapist Wit
GraKee99's Avatar
Alright, thank you for clearing that up.
Sorry for the thread jack Daladim.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #15 of 24 Old 02-18-2010, 10:45 AM
CJ258
1974 CJ5
My Jeeping buddy installed a 4 point harness and removed them within about 3 weeks. They are a pain in the @$$ for a daily driver. Besides putting them on and taking them off he could reach the cig lighter, pick up something he dropped on the floorboard and had difficulty looking over his shoulder to back up.
CJ258 is offline
wiring harnesses? nhorlacher Jeep CJ Forum 0 10-12-2009 01:22 PM
Need some narrow seats that will accept harnesses. Opinions? supraman1990 Jeep CJ Forum 6 05-05-2008 07:25 AM
Seats and harnesses NewdRiver_ Jeep CJ Forum 3 02-28-2008 01:17 PM
These the same harnesses? UGA6 Jeep CJ Forum 3 03-10-2007 05:22 PM
Wiring Harnesses and Rubber Stuff mvpco Jeep CJ Forum 4 10-09-2003 09:53 AM
