Anybody had any luck replacing tailgate end support - JeepForum.com
post #1 of 3 Old 02-21-2010, 04:13 AM Thread Starter
scorpion26
1977 CJ7
So for a couple different reasons, the piece(s) of metal directly above the rear cross-member on my cj7- I'm pretty sure it's the tailgate end support- it's where the tops of the rear body mounts bolt into and it runs all the way across the rear of the body.
this is the part i nee to replace:
rear view:
So now that I'm pretty sure I've i.d.'ed the right part, let me ask the questions.
Has any of you ever replaced this thing? how did it go? did you have to take the tub completely off the frame, or were you able to just take it loose and jack it up a little bit? From what I can tell, it's spot welded to the body, is this true?
basically any tips/suggestions will help.
scorpion26 is offline
post #2 of 3 Old 02-21-2010, 05:43 AM
keith460
Jeep. There's Only One
keith460's Avatar
You won't be able to remove or install that piece without having full access to the area and that means tub removal. Welds will have to be ground down and spot welds need to be drilled in order to remove. You will even want to turn the tub upside down in order to get to most of the welds that are holding the splash panel part of it to the rear floor section. I had a similar repair to make to a brand new Repli-tub that the tailgate support was not made correctly in order to fit over the stock gas tank location. PIA to do and my tub was completely of the frame.
But, if you are really set against removing the tub for this type of repair, then at least remove the gas tank and see what you are up against and what will be in the way. Anything is possible as long as you have the right tools at hand and trying to replace that piece with the tub mounted to the frame is going to limit your ability to maneuver any tool around to gain access to welds that must be removed.
1984 CJ-7 Renegade
keith460 is offline
post #3 of 3 Old 03-25-2017, 06:18 PM
jsonhd
very detailed pics
jsonhd is offline
Wish me luck on Carb Rebuild! pcg7384 Jeep CJ Forum 44 02-05-2010 08:47 AM
had some good and bad luck with the cj brian613 Jeep CJ Forum 6 11-14-2009 06:47 AM
What is the size difference of an early CJ5 tailgate vs. a CJ7 tailgate? JeepsOLot Jeep CJ Forum 3 02-22-2009 10:46 PM
Redundant HEI question. (Sorry, did a search with no luck) jatepper Jeep CJ Forum 19 07-18-2008 12:01 PM
Clutchs everyone has had good luck with kcrich929 Jeep CJ Forum 5 01-31-2005 11:10 AM
