#1 | |
Any tips on painting a hardtop?
My CJ hardtop is beat to hell and all scratched up. Anyone ever paint one themselves or do I have take it to get professionally done? If I do it at home, should I sand/prime it? Thoughts?
1983 CJ7 - Project "Surf Jeep Restoration"
#2 |
Depends on what you want you can get a decent paint job out of a rattle can,lol. Or if you not worried about perfectiontapeup the glass and let it rip!
http://i177.photobucket.com/albums/w211/gt4660/DSC00980.jpg
08 2dr Rubicon 79 CJ 7 258, T150, dana 20 |
#3 | |
Did you paint the one in the picture with a rattle can? Does it hold up okay? Any priming?
#4 | |
tips?
don't sand it... do make repairs... don't use gloss... do spend alot of time on prep (cleaning)... don't skip the previous step... do it yourself at home. Hoss
Don't mind me, I'm just another FNG around here...
#5 |
you can sand it after a good cleaning with a scotch bright pad..But I know what your geting at about sanding,taking off the texture..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1 1984 cj8 350 on 35's..the wifes [QUOTE=Me] "offroad it, and wave then you might understand"[/QUOTE] BLS Home Chapter... Where it all Started :hahaha: yj My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL] |
#6 |
It holds up ok 3rd jeep i have done, great thing about isyou can always touch it up. I did not prime it just cleaned it and sprayed...
#7 |
Okay so I'm gonna tackle it at home. Spray it or roll on the new paint?
#8 |
krylon, shake and go
#9 |
Be careful sanding that fiberglass; you will want to wear gloves and a long-sleeve shirt or else you will be itching and burning for a week...
The good part is that fiberglass repairs are fairly easy (I've worked with fiberglass boats a lot, so it's simple to me at least) and you can pick up fiberglass repair kits at almost any parts store. If you have deep scratches or cracks, you will want to fill those in, then sand the surface smooth. It really depends on how bad and how deep those scratches are.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress) 1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress) |
#10 |
I used a small roller and a can of satin black Rustoleom paint and it turned out great. I have also spray painted them. The roller works much better!
#11 |
Did mine with Rustoleum premium rattle can black satin. They make a little device that clips on to the can so you just squeeze a trigger, saves your finger. I used 5 cans and all I did was wash it down real good. Came out awesome because of satin and the texture it looks great can't tell its rattle canned.
#12 | ||
they just look plain wrong when they are shiny and/or smooth. Definitely a DIY project though...Good Luck Hoss
#13 |
I've seen pretty good lookin tops done with Herculiner, Durabak, etc... A guy I work with does MegaLiner and he says he can do metal, wood, fiberglass almost anything. The texture would be comparable to original and would last.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
