Quantcast Any tips for a hard top hoist? - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep CJ Forum > Any tips for a hard top hoist?
Old 03-24-2005, 08:54 PM   #1
buzzard86
Have any of you guys fabricated your own hard top hoist and care to share some ideas? I googled the topic but was less than impressed with the findings. Don't really want to buy as I've heard that the quality of most was questionable and they're all quite expensive. I was thinking about just fabricating something using a pulley and winch system, but I'm having some difficulty figuring out how to grab the back of the top.
Interested to hear your ideas and, if possible, see photos. I'm open to all suggestion. My only requirement is that I need to be able to make it with regular tools (ie, I don't weld) and would prefer that parts be found at the big boxes like Home Depot, Lowes, etc.
Thanks!
JIM
1986 Jeep CJ7 Renegade
65,000 miles
1997 Jeep XJ Cherokee Sport
Daily Driver -- 111,000 miles and counting!
buzzard86 is offline   Reply With Quote
Old 03-24-2005, 09:10 PM   #2
Slipslap
I am fixing to make one. I am gonna use 2 4x4 posts and a 2x4 on top. I will slot the 4x4 posts to put the 2x4 in lengthwise for more strength. The mount a pulley in the middle and on the post. Then rig up 4 lines to hook the corners and use a boat winch to lift it so you can pull out from under it. And then lower it so it's not putting a strain on the winch or frame.
Slipslap is offline   Reply With Quote
Old 03-24-2005, 10:31 PM   #3
dawgates
1980 CJ7
Go buy one of these cheap come-a-longs at Harbor Freight. It will hoist an undressed deer, it will hoist a hard top.
Install a 3/8" eye bolt in your garage rafter, slide a 2x4 front to back and another side to side (cut 2x4's so 4" or more stick out from each side of the top). Secure some rope in the edge of each 2x4 that's sticking out from the top (drill hole, tie knot in bottom), tie them together just behind the doors above the roof. Hook your hoist to the eye bolt and the top, then test your lift to make sure you're close to the middle of the weight. Adjust if needed.
I used this for a friends Miata. It would great until he walked into the top one night with the lights off in the garage. Nice lump!
80' CJ7, 360 Howell Injected, 3" single exhaust, NP435 4spd, Dana 300 AA clocking ring, Currie twin stick, Tera-Low 4 -1 kit, Dana 44 front, cut 10" wider to 63", 4.10 gears, ARB, Yukon axles and Super H/D u-joints, Currie Dana 44 rear, cut wider to 60 1/2", 4.10 gears, ARB 35 spline, Currie 35 spline axle shafts, 2 1/2" x 11" Ford drum brakes, CJ-SOA conversion, Tom Woods F & R drive shafts, Warn 9500i winch, 6 point cage, Homemade F&R bumpers and tire carrier, 1" body, Pro Comp supension Kit, 12.5x35x15 BFG's, 15x10 OMF beadlocks, Body armor, OBA.
dawgates is offline   Reply With Quote
Old 03-24-2005, 10:33 PM   #4
Jeep Daddy
Look here:
http://wrangler.kicks-***.net/HardtopHoist.htm
85 CJ7 4.0L/SM465/Dana300/AMC20/Dana30, MPFI,154K miles - 33" 12.5's Pro Comp MT's, one piece axles, Detroit Softlocker rear, Lock Rite front, Warn Hubs, 4.56 R&P, 4" BDS lift, Warn x8000i, Warn winch guard, Hi-Lift, Tuffy console, Four X Dr. rocker guards, Rock Hard sport cage, Kilby OBA with 1.75 gal tank and York 10.3cc compressor, Tube fenders by GenRight Offroad, Fabricated rear bumper and tire carrier.
Jeep Daddy is offline   Reply With Quote
Old 03-24-2005, 10:43 PM   #5
dawgates
1980 CJ7
JeepDaddy,
I love it. I'll save that for when I install my hard top. But, buzzard86 doesn't know how to weld.
Maybe since he owns a CJ he should learn, don't you think?
Old 03-24-2005, 11:02 PM   #6
Geer_hed
Gotcha covered :
Stu-offroad
Darksiderz
JU Thread 1
Jeepforum Thread 1
Jeepforum Thread 2
JU Thread 2
JU Thread 3
JU Thread 4
Jeepforum Thread 3
Jeepforum Thread 4
Jeepforum Thread 5
Jeepforum Thread 6
LEVE's got a no welding hoist somewhere too.. I can't find it at the minute, but there are a couple other no welding hoists in there as well...
[center][color=black][b]85 CJ7 / 258 / T176 / Dana 30/ AMC 20[/b][/color]
[url=http://www.geocities.com/cantwait_forviolence/]My Online Dumping Ground[/url][/center]
Geer_hed is offline   Reply With Quote
Glock Forum
