any ideas? - Page 2 - JeepForum.com
post #16 of 19 Old 06-12-2011, 04:06 PM
mopar408
1974 CJ5
this
while shoving engine/ transmission around to try to slide the engine in, the shifter shifted in to 1st or 2nd gear, and now i cant get it out of gear!
But try the other ideas first. But it is easier to stab w/ toploader off and shifter out of way,it gibes you a chance to inspect a lot of critical things, look for water in tranny etc. plus filling w/ lube you just pour it in.
My bet it's something else anyway.
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
post #17 of 19 Old 06-12-2011, 06:06 PM Thread Starter
jetguy
i'll get at it in the morning and update later. i hope it is not too hot out!
jetguy is offline
post #18 of 19 Old 06-13-2011, 08:14 PM Thread Starter
jetguy
ok , it turns out i have the t176 (yeah! its better than the t4!!) i dropped the d300 and t176 today. once i got the t176 out and spun the input shaft, this freed up my stuck stick shift. i also got the stuck pilot bushing out by drilling 2 little holes it it and chisseling it out. i have been sanding the outside dia. of the new pilot bushing so it goes in easier and does not crush the inside diameter of the pilot bushing. i also bought a tranny jack so i can get everything lined up just right (and not crush myself). looking fwd to getting alot done tomorrow. i want to have my rig running in the next 6 days!!!!!
jetguy is offline
post #19 of 19 Old 06-13-2011, 09:07 PM
gone2hatteras
1983 CJ7
On my 83 I used a pilot bearing not a bushing but the bushing will do the same job.
It sounds like you've got yourself a plan, just take your time and it come together.
Good Luck and I hope it'll go together smoothly for you.
gone2hatteras is offline
Undoing PO's bad ideas, body lift. Need lift ideas jpywell52 Jeep CJ Forum 5 03-01-2011 08:04 PM
SPARE Axle Storage Ideas.... any other ideas? Fjguercio Jeep CJ Forum 3 12-10-2009 08:54 AM
I'm getting ideas from this! JeepHammer Jeep CJ Forum 17 09-24-2009 12:07 PM
SHARE IDEAS!! Need custom exhaust ideas for Chevy 350 Turbo! DWK213 Jeep CJ Forum 3 04-18-2009 08:57 PM
Looking for ideas... djfuzzy Jeep CJ Forum 4 06-09-2004 06:42 PM
