ANy idea whats wrong with my axle? - JeepForum.com
post #1 of 8 Old 02-10-2006, 05:49 PM Thread Starter
jeepin cj-5
SO I just got gears put in my dana 44s in the summer and basically my rear end is gone. The yoke bearing seems to be completely gone i mean the yoke will move a quarter inch in all directions and will pull out like a quarter inch. What do you think this is?... is it a matter of a bearing or am i goin to have to have the axle rebuilt. There are no metal shavings in the gear oil and the ring gear looks perfectly fine.
I started noticing the problem because it seemed like there was alot of play in between the time I let off the gas till the compression braking started in the gears if tht makes sense. I have pictures and a video of the yoke but i dont know how to post either.
Any help at all would be great
1973 cj5- needs alot of work
1985 cj7- SOA w/ Re 1.5" springs, Scout dana 44's, 4.56 gears f/r with full detroit f/r. Flattop knuckles and highsteer. Custom steering with 1 ton TRE's. Procomp es 3000 shocks w/ f250 shock towers. Tom Woods rear d shaft, 37" MTR's... with more and more sh*t piling up
jeepin cj-5 is offline
post #2 of 8 Old 02-10-2006, 06:00 PM
Bard
I would re-torque the pinion bearing and pull the rear cover and recheck the carrier bolts as well. Sounds like it wasn't tightened down right. Also check your U-joints as well, could be something simple.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #3 of 8 Old 02-11-2006, 03:29 PM Thread Starter
jeepin cj-5
is this something that is worth fixing myself or should I pull the axle and take it back to the guy who put it in
.... the other thing i dont understand is what is allowing the pinion to pull out like a quarter inch... would that happen if the bearing was shot
post #4 of 8 Old 02-12-2006, 07:20 AM
nozzleram
nozzleram's Avatar
If your pinion is moving like you describe I'd stop driving it and get it towed back to where you had it installed. That is drastically wrong. A pinion gear that moves a quarter inch is not a good thing. I can't believe your ring gear is still looking good. With the money it takes to build an axel in a shop I'd be screaming for a warranty repair.
77 CJ 7 - 304, TH400, Dana 300, Locked Scout 44s F/R, 4140 Chromoly Shafts, Bead locked TSL Q78s
nozzleram is offline
post #5 of 8 Old 02-12-2006, 07:31 AM
cjbilt4me
I would first contact this guy and see what he will do.
If he is willing to fix your Jeep,just trailer it to the shop.
85 CJ7,9"HPC/ Detroit,44 spooled,SOA,36 IROCS,Redneck Ram,300/twin stick/Tera Low,MPFI,Premier Welder,Warn 9000I
cjbilt4me is offline
post #6 of 8 Old 02-12-2006, 07:32 PM
tahoe wheelers
tahoe wheelers's Avatar
Id pull the diff cover and check the ring gears, if the shiney coating on the gears is wore off, you will be buying a new ring and pinion. If this is true contact my buddy over at Randys Ring and Pinion, his name is Tom Whitney and he'll take good care of you.
1985 cj 7. 360 V8, 35X12.50 BFG's sitting on Crager 15X8 rims, summer brothers axle rear, Yukon axles up front, lock rite lockers front and rear, 5" of lift, body armor, six point roll cage, 8000lb warn winch, 4.56 yukon gears front and rear, t-18, dana 300. And much more on the way.
color="Blue">www.reno4x4.com
tahoe wheelers is offline
post #7 of 8 Old 02-12-2006, 07:55 PM
80cj
80cj's Avatar
1980 CJ5
I imagine the rearend gears were pretty noisy before all this happened?
80cj is offline
post #8 of 8 Old 02-13-2006, 05:01 AM Thread Starter
jeepin cj-5
it went through a period of being noisy when there was water in it, but after i discovered that and fixed it it wuited back down.... based on the fact that water was involved im thinkin I will pull the rear end and take it to a local shop (here at school in blacksburg) and see what they have to say... see it its an improper installation deal or a problem of having water in it.
Whats wrong with my PS pump - gets HOT DuggerCJ Jeep CJ Forum 3 08-10-2009 10:06 PM
Replaced Hi pressure power steering line. Whats wrong slick351 Jeep CJ Forum 4 11-08-2008 10:08 AM
Whats wrong with my windshield??? J98cherokee Jeep CJ Forum 8 05-20-2008 02:32 PM
New windshield frame - whats wrong? JeepJedi Jeep CJ Forum 10 04-16-2005 02:20 PM
Whats Wrong????????? DEERSLAYER1407 Jeep CJ Forum 10 11-16-2004 07:29 PM
