Another wiring question; wiring alternator to volt gauge? - JeepForum.com
post #1 of 4 Old 07-17-2010, 03:03 PM Thread Starter
Jeepguy91
I am trying to wire up my alternator by going off of the diagram that Jeephammer showed me. Was wondering if anybody could tell me where i would run the wire to the gauge? I have got aftermarket gauges installed but don't know where the wire would come from off of the alternator? All of my wiring is from scratch. I didn't use a wiring harness. Here is a pic of the diagram that i am going by. Any help would be great.
Thanks,
Ben
2000 XJ limited-3" rough country, winch, winch bumper, 31" BFG at's
98 ZJ Limited 5.2- FM 40
Jeepguy91 is offline
post #2 of 4 Old 07-20-2010, 04:14 PM
mxdano
1982 CJ7
If you are wiring a volt meter you can wire the + to your ignition switch so it will read voltage when the key is on. If you are wiring an amp meter it needs to go inline from the big +(Bat) post on the back of the alternator, (between alternator and battery). Most gauges read voltage and are simple to wire. + to ign and - to ground.
mxdano is offline
post #3 of 4 Old 07-20-2010, 04:42 PM
Torxhead
On my '86, the voltmeter is tied into the yellow wire that goes to the windshield wiper motor fuse.
Torxhead is offline
post #4 of 4 Old 07-20-2010, 04:46 PM
mxdano
1982 CJ7
Any wire that has 12V when key is on will work.
mxdano is offline
alternator , gauge , volt , voltmeter , wiring , wiring harness
Volt meter wiring h2ojeep Jeep CJ Forum 6 07-04-2010 06:00 PM
Aftermarket Volt Meter Wiring Muttmutt Jeep CJ Forum 1 04-07-2009 03:16 AM
fuel gauge wiring question rodjr Jeep CJ Forum 6 11-01-2008 11:09 PM
Wiring / fuel gauge question - no power JarWithLid Jeep CJ Forum 1 07-02-2007 01:03 PM
Another fuel gauge wiring question RJsfun Jeep CJ Forum 1 01-30-2006 04:03 PM
