Another Jeep CJ7 Build - Page 10 - JeepForum.com
post #136 of 163 Old 07-11-2009, 07:29 AM
AlaskanCJ
1984 CJ8
Wow! Impressive.
AlaskanCJ is offline
post #137 of 163 Old 07-12-2009, 10:24 PM
Evian
Ok, now that it is finished what is the total cost to restore this beauty?
Evian is offline
post #138 of 163 Old 07-13-2009, 03:35 PM Thread Starter
andresesquire
Thanks everyone for the thumbs up. As far as the cost to do the restoration....I'd rather not say...just in case my wife stumbles on to this thread! Seriously though, if I added it all up, I probably could have bought a new jeep with all the bells and whistles, but I much rather have and drive my CJ.
andresesquire is offline
post #139 of 163 Old 07-13-2009, 05:45 PM
CopperCJ7
AMEN! Exactly how I feel...about my wife not seeing what I spent on my CJ-7
Guns don't kill people... Bad trail spotters do.
What CJ owner doesn't want to hack up his harness for the next owner to have fun with?
Originally Posted by Broseph View Post
The thread will derail quicker than a walrus on a Crisco-soaked Slip 'n' Slide.
CopperCJ7 is offline
post #140 of 163 Old 07-13-2009, 06:23 PM
jatepper
X 100000000 I learned to get all my parts shipped to work!
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #141 of 163 Old 07-13-2009, 06:46 PM
CopperCJ7
Very good call! BUT even though you're a Marine (and thank you) if you were married to an Irish redhead (like I am), all the Marine training in the world would make you run for the hills if she ever found out what you spent on the Jeep. I was going to burn all my receipts and then drove them to my parent's house (55 miles away) and put them in their safe... in case I need them for the insurance thing.
post #142 of 163 Old 07-13-2009, 08:25 PM
jatepper
Well, I dont COMPLETELY lie to her. I tell her what I'm buying, but usually tell her it costs about 60% of what it really costs. Wife is not dumb and she dosent think these jeep parts just magically show up
jatepper is offline
post #143 of 163 Old 01-16-2010, 04:47 PM
trebor3009
Great thread and Impressive work! Your build is a source of motivation for me.
How do you like the superride suspension lift?
trebor3009 is offline
post #144 of 163 Old 01-17-2010, 03:13 PM Thread Starter
andresesquire
Thanks trebor3009.
I don't care a bit for the superride suspension kit. There is nothing super about it, it is one rough ride. I've done everything to soften the ride, including loosen the shackle bolts, applying synthetic greese, opening up the clamps. Nothing has worked. There is literally no flex. I would reccomend against them.
Good luck with your future restoration.
post #145 of 163 Old 07-02-2010, 11:04 AM
andyt86CJ
where did you find that carpet kit ? I need the same : )
andyt86CJ is offline
post #146 of 163 Old 07-02-2010, 11:20 AM
Guitar
Try 4WD.com 4 Wheel Drive Hardware Search-RH2
1984 Blue CJ7 Renegade
Guitar is offline
post #147 of 163 Old 07-02-2010, 11:28 AM
andyt86CJ
thanks !
post #148 of 163 Old 03-10-2011, 08:28 PM Thread Starter
andresesquire
I have enjoyed my CJ for a few years running basically a stock setup with a Carter BBD type carb, minus the stepper motor, computer i.e. Nuttered. I've also added an aftermarket air conditioner for my mall crawling comfort.
I have never been satisfied with my mpg. In fact it has been abysmal! I am lucky to get 8 or 9 mpg. Last summer I drove to the upper keys from the Tampa Bay area and had to stop for gas five times. For those familiar, I fueled up at the last exit in Naples and nearly did not make it across Alligator Alley. Also, driving on the interstate is uncomfortable and I nearly have to floor it to merge into traffic.
I decided to take the plunge into the world of fuel injection. I did a lot of thinking and research and decided that I wanted to go with MPI. I also decided I was not going to shell out $2,500+ for a kit. That left only the junkyard option. Feeling adventurous, I began one of many trips to the junkyard.
First I started with an MPI intake from a Jeep Cherokee. Those Jeeps are a dime a dozen in most yards.
Cleaned it up and made all the alterations to the intake to make it fit, and then I polished it up with a wire wheel. BTW, a wire wheel leaves cast aluminum looking like chrome.
Then I went about looking for a wiring harness and computer. One night while looking on eBay I found a used MPI/Hesco kit minus the damper and intake, which I already had for $150!!!! What luck, it included the special PCM, distributor, CPS sensor and bracket, air cleaner setup with K&N filter, all sensors and the Hesco wiring harness with just the required wiring.
I had to buy an electric fuel pump which I found new on eBay for less than fifty bucks a new damper. I already had the right spark plugs and wires from my team rush upgrade.
Took me about a week to finish the job with the help of my uncle. The hardest parts of the conversion for me was dropping the fuel tank to replace the fuel hoses and removing the damper. Other than that, it was a bit of a chore keeping the engine compartment organized the way I like it.
When I started the engine for the first time, I forgot to even finger tighten the nuts holding the fan and fan clutch to the pulley. That plus a big leak in the intake gasket making the engine rev to over 5,000 rpms drove the fan nearly through the radiator. Yeah, it was toast, along with the clutch, and fan. Oof!
So, I decided to get an aluminum radiator and rather than replacing the stock fan and clutch I would do the Ford Contour electric fan upgrade. Then I learned that the fans draw a ridiculous amount of current that the 60 amp alternator could not handle.
So, I decided to upgrade the alternator to a CS144 140 amp alternator from a Cadillac Deville. Bolts right up, just had to get a special plug from Napa that includes a special resistor in the exciter wire.
Added a thermostat fan control and finally finished the conversion.
Now the Jeep runs great and I get a lot better gas mileage just in time for the crazy gas prices. Here are pics of the finished product:
For a little over what I paid for that new carb a few years back, I have a much more efficient setup. While itís no longer stock, I can live with the benefits just fine. My only regret is that I did not do it earlier. I think the upgrade is a no brainer. Why bother with the carbs? The endless debates on which Weber is better or the proper way to tune a Redline carb, messing with idle tubs and jets.
Just do it!
post #149 of 163 Old 03-10-2011, 10:18 PM
dkg4244
1983 CJ8
First time seeing this thread. Awesome job! Makes me want to build up a 7.
RIP 1997 2 Door 5 Speed XJ 3.5 RE Super Ride Kit, 245/75/R16 Maxxis Bighorns
1983 Scrambler
1955 Willys Pickup
dkg4244 is offline
post #150 of 163 Old 03-10-2011, 11:02 PM
Capt_Drake
That is good lookin
for you
Capt_Drake is offline
My jeep build :} Sedorbrian Jeep CJ Forum 0 06-20-2009 06:44 PM
Want To Build My First Jeep Dementius88 Jeep CJ Forum 18 02-13-2009 09:56 AM
Jeep build ajstewart Jeep CJ Forum 2 09-18-2008 01:37 PM
tell me what you would do. '76 jeep cj-5 build locogringo Jeep CJ Forum 8 06-21-2008 12:01 PM
Jeep cj7 401 build up jeffarcher401 Jeep CJ Forum 0 07-08-2007 08:58 PM
