Another Headlight Relay Mod Thread - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Another Headlight Relay Mod Thread
ZONE 4.25" combo lift for TJ available at Rockridge4wJeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinRIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 09-21-2014, 06:19 PM   #1
batmn77
1982 CJ7
Alright, here is the dilemma: I have wired up my relays and spliced into the factory high and low beam wires. The high beams light up, but the low beams do not. I replaced the dimmer switch and it still does the same thing. Also, if I take the "trigger" wire and connect it directly to the battery the low beams work. Could the actual headlight switch be bad?
They Cant Stop Me, Even If They Stopped Me.
Car History from 1st to Present:
-1997 Mustang V6 (Sold); -1999 Chevrolet Blazer (Sold); -2001 Chevrolet Silverado Z71 (Sold); -1999 Chevrolet Z28 Camaro; 1982 Jeep CJ-7
batmn77 is offline   Reply With Quote Quick reply to this message
Unread 09-21-2014, 06:54 PM   #2
waterdowg
Did you have Low Beams before you put in the relays?
waterdowg is offline   Reply With Quote Quick reply to this message
Unread 09-21-2014, 06:56 PM   #3
batmn77
1982 CJ7
Yes, everything worked perfect before starting this project.
Unread 09-21-2014, 09:31 PM   #4
CSP
If the headlight switch was bad the highs wouldn't work.
CSP is offline   Reply With Quote Quick reply to this message
Unread 09-22-2014, 05:54 PM   #5
Spieg8
1984 CJ8
Should be pretty easy to track the problem if you have a volt meter or even a test light. Are the fuses/circuit breakers/fusible links (whichever you are using) all okay? Sounds like you are getting battery power to the relay, but not getting power from the factory wiring coming from the dimmer switch. Gotta be a bad dimmer switch or wiring between the switch and the relay (check your splice and that the plugs are all seated completely).
Spieg8 is offline   Reply With Quote Quick reply to this message
