Another dash lights problem - JeepForum.com
post #1 of 3 Old 08-22-2013, 10:55 PM Thread Starter
kooch
1982 CJ7
OK so new to posting but not new to the forum. I did a search but im not having the same problems....I don't think.
I have a 82 cj-7 with the I6. no radio.
so here is what works on the dash. oil gauge, speedo, temp gauge, turn signals(bulbs light up) and all heater and wiper motor works.
Heres what im trying to accomplish. I just want the speedo bulbs to light up. so i fallowed the orange wires all the way to the fuse with my test lite and no power at all. If i test on any other fuse it lights up??
Do I un screw the fuse box and check the back or am I missing something. I have a coloured wire diagram and that helps.
If it matters I don't have a HI/low beam its just low beam. I think the PO might have changed some wires. Ill post pics. to go with what im talking about.
Wires are intimidating.
Thanks for the help!
kooch is offline
post #2 of 3 Old 08-22-2013, 11:05 PM
only in a jeep cj
The orange wires are the dash lights both at the cluster and the small signs next to the cables.
Check the plug at the light switch.....and the switch too. Clean contacts and replug firm.
For HI beam, you should have 3 wires on the floor at the foot activated dimmer switch. Check the plugs/contacts...Center wire is hot (I think)
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 3 Old 08-23-2013, 12:33 AM Thread Starter
kooch
1982 CJ7
Ok as for the floor switch or "hi/low" switch. On mine the PO made it an egnition switch. Maybe an anti- theft??? One click with my foot....turn the key it will start right up. If I turn the engine off and click again with my foot and turn the key it try's to start but never will. Click again turn key starts up. So I'm sure that's been modded.
On my way home tonight I had my headlights go on and off.
I reached under the dash wile driving to my light switch and it was hot. And I could jiggle it....seemed that moving it made the light go off and back on...my next perches is a new light switch.
kooch is offline
