Another CJ7-TH400 quit pulling - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Another CJ7-TH400 quit pulling
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4The Jeep Forum Discount is ON!
Unread 08-16-2015, 07:52 PM   #1
CJJohn01
1979 CJ7
I have a 79 CJ with quadratrac that has a part-time kit and lockouts that quit pulling at less than 3 mph on flat land while turning around . I know my chain has been stretched so I have been taking it easy to make it last until I could fix it as I have not been able to work on it for 8 months now because of colon cancer that ruptured . my question to those that may know is can the chain break without busting the case at low speeds? P.S. low range is not in neutral, and it rolls in park with hubs locked when pushed.
Sent from my C811 4G using JeepForum
CJJohn01 is offline   Reply With Quote Quick reply to this message
Unread 08-16-2015, 08:12 PM   #2
lucdog
lucdog's Avatar
1980 CJ5
If the chain is broke you would t even get 3 MPH. If it's stretched it would move, and you hear it ratcheting past the gears.
What happens if you put it in "E" or 4x4 mode?
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 08-16-2015, 08:31 PM   #3
CJJohn01
1979 CJ7
I wasn't clear , when it broke I was less than 3mph but then it wouldn't move at all afterwards. After being towed home it would roll while in park and low gear engaged. That's why I think it has a broken chain
Unread 08-16-2015, 08:32 PM   #4
CJJohn01
1979 CJ7
When in e drive or 4x4 it will do nothing but grinding sound
Unread 08-16-2015, 09:02 PM   #5
lucdog
lucdog's Avatar
1980 CJ5
I think your next step is to drain the oil from the main case, see if you can see the chain lying in the bottom, thru the drain hole.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 08-16-2015, 09:05 PM   #6
CJJohn01
1979 CJ7
Thank lucdog for your help. I will do that when I get well enough. Thanks again
Unread 08-16-2015, 09:56 PM   #7
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by CJJohn01
Thank lucdog for your help. I will do that when I get well enough. Thanks again Sent from my C811 4G using JeepForum
I hope you get well soon!!!
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 08-17-2015, 07:56 AM   #8
CJJohn01
1979 CJ7
Thanx! Chemo is till Nov. and then 3 months after that I can possibly reverse this illiostomy !!! After 5 operations, and Drs saying I wouldn't make it, I'm still fighting it every day. But so far with colon completely gone I'm cancer free...then my CJ breaks! ...go figure! Life with a CJ ! LOL
Unread 08-19-2015, 10:08 PM   #9
ikidd
There's an inspection hole on the bottom of the QT used to measure chain tightness (or the absence thereof), also.
1998 ZJ 5.9 - 4", NP242
1998 ZJ 4.0 - Stock
1977 CJ7 304 Auto
1994 ZJ 4.0 "Rammy" RIP
ikidd is offline   Reply With Quote Quick reply to this message
Unread 08-20-2015, 07:32 PM   #10
CJJohn01
1979 CJ7
Can you get to it w/out removing the belly pan ?
Unread 08-20-2015, 09:27 PM   #11
ikidd
Hard to say. You still need to drain it or you'll get an eyeful.
1998 ZJ 4.0 - Stock
1977 CJ7 304 Auto
Unread 08-21-2015, 08:42 PM   #12
CJJohn01
1979 CJ7
O.K. thanx for the info. Like I said it will be a while b4 I can do it but I will keep everybody posted
