Another CJ owners initiation, body mounting bolt size - JeepForum.com
post #1 of 4 Old 02-03-2013, 06:50 PM Thread Starter
auskier
1983 CJ7
Well,
I think the title says it all, after 30 years on what appear to be stock body bushings, I decided that my CJ needs to have them replaced. I'm taking it down to repaint the PO's sorry job of taping and spraying over everything, and fixing a rust/bonds spot that was repaired with window flashing and 3/8" of bondo.
Now onto the body mount bolts. I have 3 that broke off, the 2 under the roll bar and one under the drivers foot. I still have to remove the ones by the fuel tank. Does the tank have to be dropped to remove these? Is the best way the fix the broken ones to cut holes in the floor?
Last, I'm looking at a poly bushing kit for the whole jeep, anybody installed one of these? Ad where to buy replacement bolts/washers. I can have the washers cut, but does anybody have a bolt size and location list?
Thanks,
Brian Ham
auskier is offline
post #2 of 4 Old 02-03-2013, 09:34 PM
1986cj
Look above, in the CJ stickies thread
1986cj is offline
post #3 of 4 Old 02-04-2013, 06:37 AM
Redmanchew
Redmanchew's Avatar
1982 CJ7
http://www.jeepforum.com/forum/f8/bo...-bolts-534218/
me sticky, su sticky...:-)
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #4 of 4 Old 02-05-2013, 08:42 AM Thread Starter
auskier
1983 CJ7
I have decided to go with a 1" daystar poly lift kit. It will give my 35" tires a little more clearance.
auskier is offline
