Another CJ Axle Swap Question - JeepForum.com
post #1 of 16 Old 09-16-2015, 07:17 AM Thread Starter
mamllc
I just got a 76 CJ5, still all original 304/4speed. Not quite sure what I want to do with it, just thinking out loud and wanting to get my ducks in a row before I start spending money. I am pretty sure I want disc brakes on the front and may want to go to 35" tires. Do the 74-9 Wagoneer front Dana 44s all have disc brakes on them? My thinking is that I could shorten the Wagoneer front but keep the hubs/brakes as is. Moser says they can make one piece axles for the AMC 20 with the 6 lug pattern to match the Wagoneer front for about $100 over the cost of the regular one piece axle. This seems like it would be cheaper and easier than swapping parts on the front to match the 5 lug rear. How compatible are the 44 steering parts with the CJ? The sheet metal on this Jeep is rough already so I am hoping that I can make whatever tire clearance I need by lifting the body and trimming the wheel wells, hoping to avoid as many steering mods as possible. What are the limits of the D30 I have in the front now? I know I can get better axles for it but I don't want to start putting money into it just to end up replacing it.
mamllc is offline
post #2 of 16 Old 09-16-2015, 08:37 AM
texasdave
texasdave's Avatar
1980 CJ7
I know 79 Waggies had discs. To solve the lug pattern I got a Dana 44 rear axle out of a Isuzu Trooper. Honda passports also have them and are six lug. You may have to regear to match the ratio. Another advantage is they have rear disc breaks
texasdave is offline
post #3 of 16 Old 09-16-2015, 08:56 AM
CSP
Any Waggie front 44 will have disc brakes. Steering will have to be custom made when you shorten it, but that's easy.
CSP is offline
post #4 of 16 Old 09-16-2015, 11:04 AM Thread Starter
mamllc
Have to total up the parts and see what they cost. The 20 with axles and a truss (which I can make) is said to be as good as a 44, with the added advantage of already being in place. Disc brakes on the back would be OK, not sure how far I'd be willing to go to get them though.
mamllc is offline
post #5 of 16 Old 09-16-2015, 11:08 AM Thread Starter
mamllc
Good news on the brakes. "that's easy" you say. OK, can't be the nastiest pit I've ever blindly jumped into.
mamllc is offline
post #6 of 16 Old 09-16-2015, 11:29 AM
texasdave
texasdave's Avatar
1980 CJ7
With the Isuzu rear end all you have to do is move the spring perches. Pretty cheap in junk yards.
post #7 of 16 Old 09-16-2015, 11:37 AM Thread Starter
mamllc
Worth checking into. Do you know what the width is on that rear?
mamllc is offline
post #8 of 16 Old 09-16-2015, 11:58 AM
TIPPEDITOVER
In the Lab
TIPPEDITOVER's Avatar
1978 CJ5
I can tell you it matches the Waggy D44 perfectly and the disc brakes are sweet. But you gotta get one out of a 96 or 97. Those two years are the best match to the Waggy D44 width wise. Earlier ones, too narrow. Later ones too wide, plus later ones gears don't swap to D44 front. Pinion gear different length.
Two minor drawbacks worth mentioning about the Isuzu D44 is it has thin wall tubes, would be prone to bending if any serious abuse was planned. Easily fixed with a truss to strengthen.
Only other thing worth mentioning is most came with 4.30 gear ratio, which is not bad if you're running 33's. What's bad is if you ever want to buy a new set of gears. Big money for that ratio. It's not sold much in the aftermarket, so the price is sky high. If you are comfortable swapping gears around, pickup an extra set of junkyard Isuzu D44 4.30 gears (97 or earlier versions). They will fit the Waggy D44 front axle perfectly. Did it to my Dad's last winter. Paid $100 for used good gears and it worked out great.
Shaun
1978 CJ5 to CJ6 - Build in progress......
TIPPEDITOVER is offline
post #9 of 16 Old 09-16-2015, 12:14 PM Thread Starter
mamllc
Would the earlier, pre 96 axles have better tubes/gears, and how would the width compare to my original CJ axles?
mamllc is offline
post #10 of 16 Old 09-16-2015, 12:14 PM
TIPPEDITOVER
In the Lab
1978 CJ5
Oh and worth mentioning about the Isuzu D44, they all used the 3.73 and down carrier. They installed "thick cut" 4.30 gears to make it work. They beauty is those same "thick cut" 4.30 gears fit any 3.73 and down D44 carrier, which is most likely the type of carrier your future Waggy D44 will have.
Because the Waggy D44 is low pinion config the Isuzu 4.30's fit perfect and as an added bonus used 4.30 gears will drive fwd on the coast side, which was lightly worn in in their previous life in the Rodeo.
Shaun
post #11 of 16 Old 09-16-2015, 12:16 PM
TIPPEDITOVER
In the Lab
1978 CJ5
They all had thin wall tubes. The width of the earlier ones will still be considerably wider than your original CJ axles, plus the lug pattern is different. The lug pattern matches the Waggy D44 though.
Shaun
post #12 of 16 Old 09-16-2015, 05:52 PM
lucdog
lucdog's Avatar
1980 CJ5
Tipped, I disagree with the thin wall tubes. My Isuzu 44 that I narrowed +- 3" to match my narrowed by 4" GM 10 bolt. Had the same tube thickness as the Dana 44 front I just narrowed.
What you don't want is the later Isuze/Honda 44 with the aluminum case.
The nice thing about the Isuzu/Honda 44 is the in the rotor hat E-brake. I was able to use factory CJ cables with slight modification to work the E-brake
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #13 of 16 Old 09-17-2015, 11:22 AM
TIPPEDITOVER
In the Lab
1978 CJ5
I can't remember the exact circumstances that gave me the impression they had thin tubes. I saw something during the build of my Fathers axle and it made me wonder if it would be good enough.
I vaguely remember the Isuzu's tubes to be around 3/16" thick. I suppose that's good enough. My Dad hasn't had any issues with his and it's been through some pretty tough situations. We left it the way it came out of the Rodeo.
OP, some other tidbits, the 95 and prior ones measure 57.5" wms to wms. That is 7" wider overall than your stock narrow-track AMC20 rear. So no, it's not a good match to your original D30 front axle, besides for the issue of lug pattern mismatch. One other thing I remembered is you have to replace the driveshaft yoke because the stock Isuzu one is a flat 4 bolt style that isn't desirable. That's easy to do.
Shaun
post #14 of 16 Old 09-18-2015, 12:43 PM
Chewtoy
1976 CJ5
Here's a thought, I have the Waggy / Rodeo combo myself and love it, but if all you want are disc brakes, they were an option starting in '76 and standard on '77+ so it should be just a matter of getting the oem stuff from NAPA and changing out the drums for rotors on front and "Bobs your Uncle".
Just be careful because once you start going down that mod path it is a deep, expensive hole that you wont want to climb out of All I wanted to do was put alloy axles in my 20 which turned into D44s front and back, air locker and truetrac, then added a proper spring over lift..... and ..... and.... it just never ends. But it is a fun sickness, welcome to club.
With a great Jeep comes an empty wallet.
Chewtoy is offline
post #15 of 16 Old 09-18-2015, 01:06 PM
chevyjunky77
1977 CJ7
Standard on a '77 is not true. Early '77s had drums, late year '77s have disc. Here is what I drew up for a guy that wants to convert to disc.
http://www.jeepforum.com/forum/f8/cj...grade-3400114/
chevyjunky77 is offline
