Another Caster angle questions - JeepForum.com
post #1 of 2 Old 02-23-2009, 07:40 PM Thread Starter
Dad03
1975 CJ5
OK I put an angle meter on top of the castle nut. It reads 6 degrees to the firewall. Is this positve or negative? Which way is within specs? If its out any idea how big of a shim to install?
75 CJ 5 with Dana 30
I saw the pic of meter in an earlier post but I can make out which way is the front of the vehicle.
Thanks
Dave
Dad03 is offline
post #2 of 2 Old 02-23-2009, 07:43 PM
foggybottombob
If the lower half of the inner knuckle (the C on the end of the axle tube) is in front of the upper half of the C then your caster is positive. Similarly if the lower ball joint is in front of the upper ball joint your caster is 6 degrees positive and just right.
foggybottombob is offline
How do measure caster angle? scarlett Jeep CJ Forum 3 05-23-2009 06:40 AM
caster angle questions (I read the sticky) Kingair Pilot Jeep CJ Forum 5 05-06-2008 08:08 AM
caster angle ? drunkenrich Jeep CJ Forum 2 02-11-2008 08:13 AM
Checking caster angle... 79cj7reny Jeep CJ Forum 5 11-24-2007 08:14 PM
Caster angle question jode Jeep CJ Forum 8 01-23-2007 05:41 PM
