AMP light is on - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > AMP light is on
ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!The Original 3/8" Ruffstuff Diff Cover!
Unread 07-23-2015, 07:58 PM   #1
FrontierGander
1973 CJ5
AMP light is on
Ok its a 1973 CJ5 with a rebuilt 258, 3 speed. New alternator.
This just happened recently but the AMP light turned on, went off, turned on. Didn't pay much attention because the jeep had sat for a month due to horribly made new replacement parts we get to enjoy these days. Once the new rollover valve and sending unit was it though, I've been driving it daily and the light just never shuts off, even during 65-70 MPH speeds.
Checked at the battery and its putting out (At idle) 14.28 volts and with the lights on, 13.50 volts.
I thought maybe a voltage regulator but after getting the readings, it doesn't make sense for the AMP light to be on.
FrontierGander is offline   Reply With Quote Quick reply to this message
Unread 07-24-2015, 03:48 AM   #2
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Sounds like your new alternator was wired wrong.
Or you have a grounding issue.
Is this alternator externally regulated?
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 07-24-2015, 05:41 AM   #3
steve1973
1973 CJ5
On my 73, if the amp light goes on and I know everything else is sound, I check for breaks in the wires from the alternator and external voltage regulator. It has happened twice and the brittle old wires were the reason.
steve1973 is offline   Reply With Quote Quick reply to this message
Unread 07-24-2015, 09:45 AM   #4
FrontierGander
1973 CJ5
yes external regulator. Looking into doing a swap down the road because I am going to be adding a winch shoot and that 35-37 amp alt just isnt enough.
I'll check the wiring out and see.
Unread 07-24-2015, 11:51 AM   #5
zillla
1975 CJ5
Is it the stock Motorola Alt?? Mine crapped the bed so I swapped in a CS 130 Delco alternator. The Motorolas are crap..
Pull my finger
zillla is offline   Reply With Quote Quick reply to this message
Unread 07-24-2015, 01:38 PM   #6
FrontierGander
1973 CJ5
not sure, its a refurb off ebay. Everything is charging great, just the light is in.
