amc20 one piece axle turns axle to open diff?
#1 | |
in superior axles one piece axle instructions it states they are not compatible with the traclok rear end and removal of the thrust block is required. does this mean it turns a traclok (limited slip) into an open diff after installation? also, if i have already removed a hub on a two piece axle can i just put it back on the shaft and tighten the axle nut?
thanks for your help guys, jd
#2 |
No...open carrier and Trac-Loc are two different pieces of hardware...you have one or the other and removing the thrust block doesn't turn a Trac-Loc into an open carrier.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers. '83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff. http://www.jeepskate.net |
#3 |
Are your sure that the instructions state trac-lok? The instructions that I have seen refer to the PowerLock differential as the one requiring different axles.
#4 |
Not to hijack, but what is a thrust block? In searches I have read it needs to be removed for one piece axles. Is it in all AMC20s or only in the Trac-loks? What does it do and where is it located in the dif? I tried to Google it, but it didn't answer my questions. The answer might help others with once piece axle questions.
Its only money....I'll make more tomorrow!! |
#5 |
The thrust block is a small metal shaft that is between the two axle shafts. It resides in the carrier and goes through the 2 side spider gears between the 2 axle shafts. The carrier crosspin goes through it. I don't recall what the purpose was, but it's been answered on here several times. I removed mine when I installed my locker and Moser shafts.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress) 1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress) |
#6 |
I am a few days away from purchasing the 1 Piece Superior Axles... am I correct in understanding that they will NOT work in my AMC 20 LSD??
![]() Will Yukon's work?? |
#7 | |
Cool as Ice...
http://www.jeepforum.com/forum/showthread.php?t=738341
This is how NAXJA Midwest Chapter elected officials like to treat their resident users and former multi-year supporters. <--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
