AMC 401 not holding oil pressure - JeepForum.com
post #1 of 7 Old 03-01-2009, 10:31 AM Thread Starter
wyocj
1977 CJ7
I just replaced a 360 with a 401 in my cj7 but it won't hold very much oil pressure, below 10lbs at idle right now. Was wondering if this oil pressure is to be expected or if anyone has had this problem? also curious if anyone knows of where to find high volume oil pump? thanks
wyocj is offline
post #2 of 7 Old 03-01-2009, 11:42 AM
scottymac62
1979 CJ7
There is one advertised on AM Racing's site:
http://www.amracing.com/parts/hvp001/hvp001.html
Spensive though.
scottymac62 is offline
post #3 of 7 Old 03-01-2009, 11:48 AM
SWAcapt
1979 CJ7
Did you use the oil pump from the 360? If not, and you still have the 360, you might want to swap it over. My 401 idles at 30psi and holds at about 60psi at 2500 RPM. Good luck and let us know what you find out.
http://i679.photobucket.com/albums/v...DSCN0187-1.jpg
Jeeps..... Because 99.997% of the world is unpaved!
1979 CJ-7, 'built 401', 4-wheel discs, Rhino-lined, 2.5 lift, Original Owner!
SWAcapt is offline
post #4 of 7 Old 03-01-2009, 12:00 PM
Andy5150
On my 360, I bought the pump gears from NAPA. I followed the assembly instructions, and at hot idle(650rpm) theres about 22psi, and anything over about 1500rpm, 58-60psi. This is with a fully warmed up motor, 90 degrees out, with Shell Rotella 15/40. I think my manual calls for 13 minimum, and 70 max, but I could be wrong.
Andy5150 is offline
post #5 of 7 Old 03-01-2009, 02:30 PM
dsl4me
1979 CJ5
IF the gauge is accurate and the oil pump bypass is working correct than I'd have to say you have bearing issues. I passed on several junkyard 360s in waggies that wouldn't hold oil pressure warm.
Did you pull the pan on the 401 and check a couple bearings before installing it?
Inspection kept me from installing a 360 that would have suffered the same fate once.
1979 CJ5 360/T15/D20
D44/AMC20 4.10s
35" Swamper SSRs
1984 CJ7 Fiberglass body
258/T5/Dana300
*project*
dsl4me is offline
post #6 of 7 Old 03-01-2009, 04:38 PM
happydog
First thing I would do is make certain that the pressure gauge is giving the correct reading. A mechanical gauge is where I would start. I believe in checking the cheapest items first.
"I don't do things, I give advice." by an old geezer in the movie "Milagro Beanfield War"
"After all, it is the slave who thinks himself a free man who makes the best slave." (Unknown)
“A closed mind is like a closed book; just a block of wood”. Chinese Proverb
happydog is offline
post #7 of 7 Old 03-01-2009, 06:45 PM
JeepHammer
Running On Empty...
1973 CJ5
Depending on how your engine clearances are set up,
You should expect between 10 & 25 PSIG at idle.
Don't know what year engine you have, but if it is '86 or older, the pressure bypass will open around 65 PSIG, so don't expect much over that at any time.
AMC V-8 engines have the oil pump built into the front timing cover, and they are made of aluminum.
Being aluminum means they move around, open up clearances, and do strange things when they get cold/warm...
Bearing clearances aren't often the biggest problem,
Often times lifter bore clearances are the largest problem in the engine.
Lifters are 16 large 'Leaks' in an AMC engine, especially if the engine is '86 or older...
Cam bearings can be large losses too, but if you are going to tear down enough to take the cam bearings out,
Might as well do the mains/rods at the same time and plug up those leaks also!
Bearing shells are cheap and easy to install...
Anyway, just replacing the oil pump WITH THE CORRECT FLOOR PLATE GASKET will often make a large difference...
Consider a 'Mid Plate' for the oil pump floor plate/filter head component,
And don't forget to service the bypass spring/plunger when you have the bottom off the oil pump.
A sticking open bypass valve can cause some pretty bad problems...
Since all that is on the OUTSIDE of the engine/timing cover and easy to change, it's the 'Easiest' way to check/do things...
If that doesn't help, the worst you have done is set up a fresh oil pump for when your engine is rebuilt/refreshed...
High Pressure pumps for a stock AMC engine is a myth.
Since the oil pump body is cast right into the front cover, there is no way to increase the speed the pump turns, or it's displacement...
Your best bet is a tight, well fitting pump to the existing housing,
OR,
Swap for a housing that isn't eaten up (if that is the problem)...
There ARE some rotor/impeller designs out there SLIGHTLY more efficient at the same speed and in the same space restrictions,
But in the long run, the 'Gains' really won't help an engine bleeding to death internally...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
He is holding a BUILD OUT HELPPP Thexonexkid Jeep CJ Forum 12 12-09-2009 06:48 PM
76' CJ7 Not Holding the Road AUSHii Jeep CJ Forum 7 09-27-2009 09:42 AM
cj5 brakes holding pressure? petey156 Jeep CJ Forum 6 07-03-2009 11:27 AM
Battery not holding a charge? mattmosman Jeep CJ Forum 10 04-17-2007 01:50 PM
AMC 20- What is holding these axles in?? hfjeff Jeep CJ Forum 20 03-29-2007 11:11 PM
