AMC 4 Barrel other than Edelbrock? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > AMC 4 Barrel other than Edelbrock?
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 05-13-2008, 10:30 PM   #1
JeepnBlake
I'm looking for a 4 barrel for my 304, does anyone besides Edelbrock make one?
-Blake-
WTB: Currie Front Uppers CE-9102, Currie Double JJ Rear Trac Bar CE-9120R, & Currie Trac Bar Bracket CE-9121N, Or Currie Rear TB with Bracket Kit CE-9123N
Build Thread: http://www.jeepforum.com/forum/f22/j...thread-985907/
OEM Fog Light Connectors, Conversions, and Extension Info:http://www.jeepforum.com/forum/f20/o...ngler-1008928/
JeepnBlake is offline   Reply With Quote
Unread 05-14-2008, 01:04 AM   #2
OldSailor
1977 CJ7
Try a Holley Truck Avenger. They come in 370, 670, and 770 cfm models.. The Truck Avenger is basically a square bore 4150 4-bbl that's been modified for off-road use. You can get it with either a manual choke or an electric choke - mine's the latter. It's rated for 40 deg nose up, 30 deg nose down, and 30 deg side tilt. I have one on my 360 and a buddy has one on his 304 and they work good. Not cheap, but neither are Edelbrocks. Mine was about $400. I've got it on an Edelbrock Performer intake manifold.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc.
OldSailor is offline   Reply With Quote
Unread 05-14-2008, 07:21 AM   #3
JeepnBlake
I didn't phrase that very well... I meant to say 4 barrel INTAKE so my question being. Does anyone besides Edelbrock make a 4 barrel Intake for the AMC V-8s?
-Blake-
Unread 05-14-2008, 09:21 AM   #4
LTICJ7Dude
1980 CJ7
The only other one I know of is Offy, and I'm not sure you can get them new anymore.
LTICJ7Dude is offline   Reply With Quote
Unread 05-14-2008, 07:11 PM   #5
Darryl
1978 CJ7
The 290, 343. 360, 390, 401 all came from the factory as either an option or as standard with a cast iron 4 barrel intake so look at all the old Javbelins, Rebels, and Ambassadors in the bone yard.
Darryl is offline   Reply With Quote
Unread 05-14-2008, 07:37 PM   #6
LTICJ7Dude
1980 CJ7
I thought he meant aftermarket...but the stock one is a good point. Quite a bit more weight than an aftermarket aluminum one, but it should be pretty easy and cheap to find.
Unread 05-14-2008, 08:57 PM   #7
243
243's Avatar
1983 CJ7
I had the Holley Z300 "Street Dominator" designed by Zuntov specifically for AMC on my Waggy. It is a single plane but it has small runners that maintain fuel/air charge velocity. They are heck to find though and not cheap.
1983 CJ7
258/T177/D300 3.54 32" BFG KM2
THE BEGINNING:
http://www.jeepforum.com/forum/f8/da...2/#post8211912
243 is offline   Reply With Quote
