AMC 4.10 Gear installation.. Help!! - JeepForum.com
post #1 of 5 Old 09-15-2009, 12:11 PM Thread Starter
acolon
I want to change from 3.31 to 4.10 on Amc 20 wide track installed in a CJ7. Does I have to change the differential case?
Thanks for your help.
acolon is offline
post #2 of 5 Old 09-15-2009, 12:21 PM
80cj
80cj's Avatar
1980 CJ5
No. On an AMC 20 3.07 and higher numerical ratios (up to 4.88) use the same case.
80cj is offline
post #3 of 5 Old 09-15-2009, 12:27 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
however, if that is the same gear your running in the front axle, then yes i believe that you have to change the carrier to go from 3.31 to 4.10's. i'm in this same boat with my 3.54's
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #4 of 5 Old 09-15-2009, 12:40 PM Thread Starter
acolon
I want to change the gear ratio in the front to 4.10 also that is a Dana 30. Here I believe that I have no choice I have to change the diff case.
acolon is offline
post #5 of 5 Old 09-15-2009, 12:46 PM
80cj
80cj's Avatar
1980 CJ5
For a Dana 30, the ratio split is 3.54 and down, 3.73 and up. If you have 3.54's you'll need to get a 3.73 diff case.
80cj is offline
360 Distributor Drive Gear Installation Hybrid Jeep Jeep CJ Forum 1 11-07-2009 10:36 AM
amc 360 installation in a c5 dieterschmied Jeep CJ Forum 1 05-02-2009 05:27 PM
top installation... poppatello Jeep CJ Forum 2 10-14-2008 08:52 AM
Top Installation 80cj Jeep CJ Forum 7 03-05-2006 07:18 PM
Speedometer gear after gear change rcsutton Jeep CJ Forum 9 01-26-2005 01:32 PM
