AMC 360 w/ Edelbrock 650 keeps flooding!!! - JeepForum.com
post #1 of 15 Old 11-23-2009, 05:03 PM Thread Starter
cracked91
1978 CJ5
Okay, so here is my problem. I have performance 360 with a edelbrock 650 on it. I have a Blue holley electric fuel pump with a regulator. The jeep runs ok city speeds and idles just fine. But at speeds 60-65+, if I put any pressure on the peddle it will start to flood and bog down. I have lowered the psi the fuel pressure regulator, but no success there. It has had this setup for a while, but only recently started flooding like this. Only other thing I can think of is that the volt regulator in the alternator is going out so the power output goes up and down. Also the fuel pump gets so hot, that I put my soft top down and it burned a hole straight through, and even melted the plastic zippers.
Can anyone help???
cracked91 is offline
post #2 of 15 Old 11-23-2009, 05:24 PM
swatson454
1983 CJ7
I had an issue with that Holley pump several years ago in which I absolutely could not keep the pressure stable. It made tuning the carb impossible. After fighting that thing for weeks I opted to never use that pump again!
Holley Carburetors
swatson454 is offline
post #3 of 15 Old 11-23-2009, 05:53 PM
nshefbuch
1982 CJ7
could it be the carb size is to big for the engine? thats alot of cfm
nshefbuch is offline
post #4 of 15 Old 11-23-2009, 06:57 PM
texasimport
1978 CJ5
I would debate that 650 is too big for a modified 360.
I would first get fuel pressure in check. Then start working on that carb.
78 304-CJ5
texasimport is offline
post #5 of 15 Old 11-23-2009, 07:45 PM Thread Starter
cracked91
1978 CJ5
Well, when i crank the pressure almost all the way down it helps alot, but it will still flood. Also, I have plenty of holes coming up from the engine compartment, but is it normal that when its flooding bad it makes my eyes and throat burn?
post #6 of 15 Old 11-23-2009, 08:56 PM
texasimport
1978 CJ5
Not exactly an expert but my 2cents. I had a holley that was so rich my eyes would water and it was due to a few things, first the secondary floats were not adjusted right and it would over fill the bowl and dump directly into the running motor, thanks PO, maybe you getting a stuck float or something got loose and now out of adjust. Also the jets both primary and secondary where to big, but that makes no sense for you, it ran right for a while right.
might consider when you change your pump add a pressure regulator.
78 304-CJ5
post #7 of 15 Old 11-24-2009, 06:10 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Set the float levels and check the needle and seats in the carb while you're at it.
cruiser54 is offline
post #8 of 15 Old 12-02-2009, 09:44 PM Thread Starter
cracked91
1978 CJ5
BUMP!! This is startin to piss me off. I got a new regulator that you manually adjust the pressure on, its got a dial that says how many pounds. No help. So I opened up and cleaned the carb out really good and replaced a broken main seal, then put it back on. It ran ok on the highway for about 20 minutes then decided to crap on me again.
post #9 of 15 Old 12-02-2009, 09:56 PM
nshefbuch
1982 CJ7
need more info. have you pulled the plugs and checked if they are fouled out? i went through this same problem and mine turned out to be first a power valve and then an o-ring let loose causing the needle valve to fail. i have a slightly modified 360 and use a smaller carb than that. i have a two barrell holley. runs great now. my personal belief is that a 650 may be two big for the motor. i think a 650 would suit a motor with 400 plus hp.
post #10 of 15 Old 12-02-2009, 10:36 PM Thread Starter
cracked91
1978 CJ5
I did replace the plugs and wires. Does yours still have the same amount of get up and go off the line with the holley 2bbl? I really am considering dropping CFMs, I just want a performance carb, not just one with low end torque.
post #11 of 15 Old 12-02-2009, 10:55 PM
jeepjunk4me
1972 CJ5
It seems that most of the improvments are coming from the fuel regulator. I would sugest replacing the holley pump with the stock one and see what happens. The electric pump may be to much even with the regulator. the carb only needs 3-5lbs press to operate. I have a 360 with same carb and am going to the quadrajet. The edelbrock floods real easy off road like holleys.
jeepjunk4me is offline
post #12 of 15 Old 12-03-2009, 08:07 AM
nshefbuch
1982 CJ7
if it were me i would go to a smaller cfm four barrell. my two barrell runs great but you can feel the torque tapper off a 4000 rpms. i plan on running a four barrell soon but will prolly go with the truck avenger 470cfm. i definetly will stay with a 600 cfm or lower.
i like the opinion of the electric pump being to much. but you can do everything you can to limit the amount of fuel to the carb, but if the carb is to big then you'll still have the same end result. alot of my buddys run a 650 cfm carb on their race cars but they are all above 400hp.
have you talked to any mechanics that know about carbs?
post #13 of 15 Old 12-03-2009, 09:15 AM
texasimport
1978 CJ5
My .02 cents. . . . Don't put a 470 TA on a V8. While the Holley web sight claims it works it will be a bugger to tune and you may fight it forever. I called Holley on this and they told me the Holley web page is in error and that the 470TA is designed for use on the 258CI 6 not a 304. You will also find that different guys at Holley will provide different statements on this topic, go figure. I am in process of trading out my 470TA now for the 670TA on a 304 motor. I spent too many weekends in the shop on a dyno along with qualified racing gear head tuners and we came to the same conclusion hence my call to Holley to tell us what we suspected, the 470TA doesn't cut it on a 304.
I am sure there are folks here that have this part running fine on their motors, good for them.
78 304-CJ5
post #14 of 15 Old 12-03-2009, 09:22 AM
jm708
2014 JK Wrangler
I have the Holley 670TA on my stock 360 and runs great when the ECM is working right. Justin
jm708 is offline
post #15 of 15 Old 12-03-2009, 01:03 PM
nshefbuch
1982 CJ7
i'm not going to argue to much on the size being to big. check the power valve and all o-rings. power valves can get a very small hole and cause it to flood. i'd replace it just to be safe.
Continuos Flooding....HELP!!!!! tamu83cj Jeep CJ Forum 13 12-14-2008 09:03 AM
carb flooding mondujen Jeep CJ Forum 9 05-09-2008 11:54 AM
Flooding boutdoorhunter Jeep CJ Forum 4 02-27-2008 07:24 AM
32/36 flooding nose down waywardfool Jeep CJ Forum 17 10-27-2005 06:16 PM
looks like flooding joe johnson Jeep CJ Forum 5 08-21-2004 10:08 AM
