Quantcast AMC 360 Vaporlock - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > AMC 360 Vaporlock
Great deals on Mickey Thompson Tires @ Jeephut.comOfficial Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFG
Old 06-30-2009, 01:29 PM   #1
Beaujeep
1980 CJ7
AMC 360 Vaporlock
Howdy. New subscriber and need some help.
Recently purchased a 1980 CJ7. It has an AMC 360 engine, Holly 4bbl Carb.
I'm having issues with the engine and vapor locking. The motor takes a bit to get started, but the trouble begins after I get her going and get up to about 35-40 mph. If I start out slow, generally I have no problems, but when I step on the gas and get after it, the engine will surge or will shut down. Any suggestions???
Beaujeep is offline   Reply With Quote
Old 06-30-2009, 01:55 PM   #2
John N
1981 CJ8
It sounds more the carb is not tuned to the engine. See if you can find a local who knows how to tune the carb; it means getting into the power valve, changing out the squirter (might not be the right term, but what we called them), re-jetting and some new gaskets.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is online now   Reply With Quote
Old 06-30-2009, 02:00 PM   #3
berserker
Check your fuel line routing to the carb. Make sure it is not running too close to the left exhaust manifold when it exits the fuel pump (this should be a steel line, not a rubber hose).
If you have headers, trace the fuel line on the left frame rail just below the firewall--that is an area that can get too close to the exhaust as well.
Ignorance can be fixed, but stupidity is forever.
berserker is offline   Reply With Quote
Old 06-30-2009, 02:30 PM   #4
Beaujeep
1980 CJ7
I had that done. Had it in w/mechanic two weeks ago, he adjusted the carb. My thinking is the carb is too big for that engine...Its a Holly 750-850, they couldnt tell for sure. When it dies, it acts flooded. Another thought is its the fuel pump...Or fuel lines getting too hot.
Old 06-30-2009, 02:32 PM   #5
Beaujeep
1980 CJ7
What is the best way to ensure the fuel lines does get too hot...Is there a good way to insulate them???
Old 06-30-2009, 03:05 PM   #6
rixcj
rixcj's Avatar
1979 CJ5
Unless it's a modified 360, a Holley 750 or 800 is too big. I run a Holley 600 on my 360, and I also ran the 600 on my 401.
I ran my fuel line like this... it's the line that snakes from the top of the frame rail, down the outside of the rail.
It's covered in a fire-resistant wrap.
I haven't done it yet, but I'm going to build a steel shroud over the part of the line that's on the outside of the frame, so that if my front tire ever came off, the tire won't rip the line off.
Plans also include extending the steel line right up to the fuel pump.
This routing keeps the line enough away from the headers. I never have vapor lock issues.
I have no fuel return line, either.
Rich
'79 CJ5, 401, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, GM HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote
Old 07-01-2009, 07:52 AM   #7
Beaujeep
1980 CJ7
Thanks for all the help!! I"ll give it a shot and see if that takes care of it.
Glock Forum
