AMC 360 oiling mod (JunkYard Genious help needed) - Page 2 - JeepForum.com
post #16 of 19 Old 11-04-2013, 09:27 AM
JeepHammer
Running On Empty...
1973 CJ5
ROB, I stumbled onto this thread again, wondered how it turned out?
I use steel braid with a jacket and steel fittings most times since they seem to crack less than brass or aluminum. Make sure the line is rated for petroleum.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #17 of 19 Old 11-04-2013, 10:41 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I went round and round on these oiling mods when I built my 360.
FWIW, the owner of Bulltear, who presumably knows AMC engines as well as anyone, told me the lifter galley bypass mod was a myth. The most common version of the mod involves restricting the flow on the galley that's opposite the bypass, in order to create enough pressure to push oil thru the bypass tube. He said that could create more problems then it eliminates.
I had the bypass mod all set up, albeit in copper . After speaking with Bulltear, I tore it out and plugged the holes. I also abandoned the little timing chain-pisser mod that is recommended in some literature.
In the end, the oiling mods I did were: Open up the main passageway from the pump, gasket match the ports, Gyptol the heads and block, and grind the casting imperfections on the drain holes . My operating pressure is consistently around 50 psi, and 20-25 psi at idle.
Matt
BypassTube4.jpg   OilPorting7.jpg   OilPorting1.jpg   OilPorting3.jpg   Glyptal2.jpg
Matt1981CJ7 is online now
post #18 of 19 Old 11-04-2013, 11:08 AM
Rollbar
1984 CJ8
Sweet-but I still see a leak on the intake
I'll have to open these up on the next 304 build for the Willy's
<----Click
<---- Click
Rollbar is offline
post #19 of 19 Old 11-04-2013, 04:48 PM
82JeepCJ7
1982 CJ7
I did not bother to mess with the oil mod when I built my 304. With motors going over 150,000 miles in the stock configuration, I was not going to bother with it. Unless your building a high RPM race engine, don't bother.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
Cam gear oiling olaf-inge Jeep CJ Forum 6 07-08-2009 04:27 PM
A Junkyard Near You: SwampThang Jeep CJ Forum 20 05-18-2008 08:50 PM
Finally found the info - AMC V8 oiling kit Bockwinkle Jeep CJ Forum 3 09-17-2007 04:56 PM
AMC 360 Oiling problems spk454 Jeep CJ Forum 1 08-27-2007 11:45 AM
AMC V-8 cam and gear oiling fuzz401 Jeep CJ Forum 2 02-19-2004 07:04 AM
