amc 360 motor mounts - JeepForum.com
post #1 of 14 Old 10-25-2010, 09:27 PM Thread Starter
Huntinchris78
I just bought and amc 360 for my 1984 cj7 and the two websites I looked at both say the engine mounts only go to a 1972-1979. Will they still fit?
Huntinchris78 is offline
post #2 of 14 Old 10-25-2010, 10:06 PM
only in a jeep cj
I can tell you that the frame side for both the 6 and 8 cyl are different for the pre 76 as it is for the post 76. They look the same at a quick glance, but the bolt holes are different for the different frames. Look for the 76 on CJ v8 style.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 14 Old 10-26-2010, 08:51 AM
CSP
What you read doesn't make sense at all, unless you're referring to the rubber cushions for the CJ with a V8, which was only produced from '72-79 (though some '80 models did have a V8). A website won't list parts for an engine in years where the factory didn't use it.
You'll need more than the rubber cushions though.
CSP is offline
post #4 of 14 Old 11-03-2010, 10:11 PM Thread Starter
Huntinchris78
I looked on advance adapters and it says the motor mounts only fit a 72-79 cj7
post #5 of 14 Old 11-03-2010, 10:17 PM
flashawk
flashawk's Avatar
1979 CJ5
They didn't start making the CJ7 untill 1976
flashawk is offline
post #6 of 14 Old 11-03-2010, 10:20 PM Thread Starter
Huntinchris78
Ok, Where can I get the motor mounts at?
post #7 of 14 Old 11-03-2010, 10:47 PM
flashawk
flashawk's Avatar
1979 CJ5
V8 Motor mounts for the AMC 304 through the 401 are the same, you need a mount from 1976 to 1986
I think these Daystar mounts at Quadratec are pretty cool.
Here's the square Daystar Polyurethane black mounts about the same price.
These are my favorites M.O.R.E. BombProof motor mounts. I think I'm getting me a set of these when I have the money.
Prothane makes a polyurethane motor mount in red or black, you're looking for a 76-86 V8 mount for the CJ-7, good luck.
1979 CJ5 360 V8 w/Holley 470 Truck Avenger, HEI Ignition, Livewires w/E3 Sparkplugs, Hedman Hedders, Flowmasters, DANA 30 w/Auzzie Locker, AMC 20 limited slip "N" 3:54's, Tuff Country 2.5" lift, Rancho RS5118, Rubicon Express Quick Disconnects, Currie 1/2" lift Heavy Duty Greasable Shackles, DANA 20, T150, Mile Marker PE8000 w/MiFi Controll Box, Bestop Super Top, Warn 6 bolt Premiums, 31x10.50x15
flashawk is offline
post #8 of 14 Old 11-04-2010, 01:24 AM
Lordwrench
1978 CJ7
There's a recent thread here saying you only need to change one side,not both.Do a search,this topic is covered alot.
Lordwrench is offline
post #9 of 14 Old 11-04-2010, 07:44 AM
Agar426
1974 CJ6
I think the reason they say that on the web sites is because they are trying to match a factory application, and the V8 was only available a certain number of years, and 1984 wasn't one of them (although I thought that '80 or '81 was the last year...not '79). Therefore, if you bought V8 mounts for your '84 CJ, they wouldn't fit because they are assuming it's stock, and you would either have a 4cyl or 6cyl under the hood.
That being said, motor mounts that fit a V8 will work in the later years. I have a set of M.O.R.E. bombproof mounts, and their application guide says that it fits '72-'86 CJs.
Agar426 is offline
post #10 of 14 Old 11-04-2010, 07:49 AM
CSP
Like I said, those are the official years that the CJ had the factory V8 (even though you can find '80 CJ with a factory V8). They will still work on '80 and up CJs.
You're not the first person that's installed a V8 in a 80-something CJ, so have a little faith that they will work.
CSP is offline
post #11 of 14 Old 11-04-2010, 12:28 PM
Superjeep3
Superjeep3's Avatar
Like others have said, you can use the mounts from older cj's that had factory installed v-8s. They will fit on your cj-7. There have been a good number of posts covering this, and pictures as well. Have faith my friend. I bought a 360 that came from a grand wagoneer (88 model) and got the mounts that the engine attached to. I ended up buying some mounts from an old cj with a factory 304 (now 402 installed) to fit in the cj-7.
Superjeep3 is offline
post #12 of 14 Old 11-04-2010, 01:28 PM
VACJ7
VACJ7's Avatar
I just bought a CJ7 frame (believe '79) that had V8 mounts on it. I just don't know what V8. I can post up some pics and maybe someone can ID them. If it is what you need you can have them for shipping.
VACJ7 is offline
post #13 of 14 Old 11-04-2010, 02:05 PM
Superjeep3
Superjeep3's Avatar
If it is an AMC engine there will be a number on the side of the engine block by the exhaust manifold (look on driver side) that will have a number (304, 360, 390, 401)
post #14 of 14 Old 11-04-2010, 04:00 PM Thread Starter
Huntinchris78
Thanks guys I appreciate the help, hopefully it'll be up and runnin soon!
MORE motor mounts billymadison Jeep CJ Forum 4 11-21-2007 07:29 AM
motor mounts v8 StewartCJ7 Jeep CJ Forum 2 09-20-2007 10:56 AM
Motor mounts shadoow Jeep CJ Forum 3 12-18-2006 10:49 AM
84 CJ7 258 - Motor mounts. jooper84 Jeep CJ Forum 2 08-21-2006 08:51 AM
Bad motor mounts? KrazyGimp Jeep CJ Forum 1 07-10-2006 07:08 PM
