amc 360 HEI no spark - JeepForum.com
post #1 of 10 Old 02-06-2010, 07:50 PM Thread Starter
rishar1
1973 CJ5
I have an amc 360 with a HEI dizzy in my project jeep and the time to start it up has come. I cranked it over the other day to see if things turned freely. I didn't have plug wires on it and I noticed the distributor arcing between the plugs on top of it. Then when I put plugs and wires on there is no spark but I have power going into the dizzy. So I thought that I blew something in the distributor so I started replacing things one by one. I have changed out everything in it and still no spark. First I changed the control module, then coil, then pickup, then capacitor. and still nothing. So what the heck is going wrong. I have all but gouged my eyes out over this thing.
1973 CJ5
1970 Chevelle SS
1974 Bronco
rishar1 is offline
post #2 of 10 Old 02-07-2010, 02:13 PM Thread Starter
rishar1
1973 CJ5
Now I am getting spark at the rotor button under the cap but it only sparks 2-3 times and then stops. I even tried another cap I had on my chevelle which runs perfectly but that didn't help. Just 2-3 pops and then its gone. Can anybody give me a hand here.
1973 CJ5
1970 Chevelle SS
1974 Bronco
rishar1 is offline
post #3 of 10 Old 02-07-2010, 02:23 PM
-AC-
1977 CJ5
As long as you're sure you have a good constant 12v to the distributor, then all it can be is something in the distributor. I know you changed everything in there, but it sounds to me that one of your parts is bad. I guess I would start with the control module... Coils are pretty basic/bulletproof, typically.
"Damn Everything But The Circus..." e.e.c.
-AC- is offline
post #4 of 10 Old 02-07-2010, 04:03 PM Thread Starter
rishar1
1973 CJ5
Turns out that the starter is not turning the engine over fast enough. I took the dizzy out, grounded it and spun it quickly by hand and it started throwing spark. Bolted it back in and took the plugs out so the engine could turn without compression and it spun fast enough to throw sparks. I guess I need to invest in a faster starter, but I've never heard of this happening. Has anyone else got any ideas besides a new starter?
1973 CJ5
1970 Chevelle SS
1974 Bronco
rishar1 is offline
post #5 of 10 Old 02-07-2010, 04:07 PM
-AC-
1977 CJ5
Dying battery. As you probably know, most auto parts stores will test your starter (or battery for that matter) for you for free, and then you'll know.
-AC- is offline
post #6 of 10 Old 02-07-2010, 04:13 PM Thread Starter
rishar1
1973 CJ5
Brand new battery. Took it of the shelf at work and brought it home 2 days ago.
1973 CJ5
1970 Chevelle SS
1974 Bronco
rishar1 is offline
post #7 of 10 Old 02-07-2010, 04:43 PM
-AC-
1977 CJ5
Which doesn't mean it's not a bad battery, but it's probably not. New starter then...
-AC- is offline
post #8 of 10 Old 02-07-2010, 05:29 PM
JeepHammer
Running On Empty...
1973 CJ5
It probably wasn't arcing between spark plug terminals,
What you probably saw was high voltage leaking from under the coil cover to the terminals or to the distributor base to reach 'Ground'...
What you probably have wrong is the center button under the coil has come apart, and/or the insulation disk (rubber/silicone) has given up and is letting the spark energy leak out every which way.
VERY COMMON with GM HEI's, and the only way you can fix that issue is with a good quality center button and insulator disk.
At this point, Your rotor is blown through, and you will probably find 'Red Dust' under the rotor and on top the advance weights.
If you look closely, you will probably see the weights/pins have been eaten away somewhat (That's were the 'Red Dust' is coming from).
When the high voltage blows through the rotor, the weights and distributor shaft are the closest 'Ground' for the high voltage.
When the high voltage strikes the weights, it will weld them to the pins they pivot on,
And then the weights break that weld, releasing 'Red Dust'.
Since the only way to make 'Red Dust' is by burning all the carbon out of steel (It's IRON rust, not steel rust) the high voltage discharges are the only thing hot enough to do that, and that tells you right away that you have rotor blow-through.
I suggest you get a new, HIGH QUALITY Distributor cap, in some color other than black,
And make sure it has BRASS TERMINALS!
(Not brass washed aluminum, take a pocket knife and scratch one, make sure it's brass all the way through!)
Also make sure you use a HIGH QUALITY ROTOR,
HIGH QUALITY CENTER BUTTON,
AND HIGH QUALITY INSULATOR DISK.
The only place I know of to get all that in one place is an MSD distributor cap kit.
Switch your coil over to the MSD cap, install the rotor and see if that helps your situation.
You might also make sure your distributor is getting a good ground to the housing.
Most people assume the housing mounted in the engine is enough, but often times.... It's not.
Oil reside builds up around the distributor housing and breaks contact with raw metal,
And the housing corrodes over, oxidized aluminum IS NOT a conductor, so pretty soon your distributor hosing is in INSUFFICIENT conductor for your ignition to work correctly.
If you purchased the 'Cheap' HEI's off the internet,
Then you might want to make sure you distributor/camshaft gears are still intact.
Doesn't take long for those cheap distributor gears to run the camshaft gear and not turn the distributor shaft at all, or at least far enough out of time you can't get the engine running...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #9 of 10 Old 02-08-2010, 08:56 AM Thread Starter
rishar1
1973 CJ5
Its a MSD hei so no cheapos here and it is brand new out of the box. Turns out the starter was a little too worn and was not spinnging the engine fast enough for the pickup coil to trigger I replaced the starter today and it fired right up. When I cranked it the first time and saw it arcing to ground it did not have plugs in it either so the engine was turning faster. I also checked the dizzy gear and it is not the hardened steel that comes with the cheapos, a plain old drill bit easily put a nice little dent in it.
1973 CJ5
1970 Chevelle SS
1974 Bronco
rishar1 is offline
post #10 of 10 Old 02-08-2010, 09:19 AM
JeepHammer
Running On Empty...
1973 CJ5
MSD is one of the few places you can get a distributor gear that is CORRECT.
NEVER, EVER run an electronic ignition without a load on the plugs/plug wires!
There is a gadget called a 'Test Plug' you should use.
Open circuit voltage can EASILY destroy the coil in short order, and it's not real good for the module.
What you experienced is common, HEI doesn't have a very strong trigger signal, mostly because of the 'Refrigerator' magnet they use to produce the magnetic field for the stator.
You have to get them spinning pretty hard to get them to trigger.
That's one reason of many I recommend the Jeep/Motorcraft distributor since they have a VERY STRONG trigger signal that works very well at low speed.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
No spark from distributor to spark plugs poolshark909 Jeep CJ Forum 14 08-06-2013 04:36 PM
67 CJ6 w/V6 - no spark cghsatx Jeep CJ Forum 6 09-05-2009 10:19 PM
no spark! trueprimitive Jeep CJ Forum 7 08-26-2009 12:52 PM
304 has no spark? 1974cj5renagade Jeep CJ Forum 0 01-04-2009 12:45 PM
No Spark to the spark plugs Dandude80cj7 Jeep CJ Forum 6 09-11-2005 09:02 PM
