AMC 360 headers - JeepForum.com
post #1 of 9 Old 03-28-2002, 09:19 AM Thread Starter
studdmc
Post AMC 360 headers
I bought an '84 Jeep from a guy last summer. He had installed a 360 in the Jeep and was running headers and glass packs that exited under the driver and passenger seats. I am wanting to run the exhaust out the rear of the jeep and maintain the dual exhaust. I am wanting to replace the headers on there already due to leaks but I can not seem to be able to find any headers that will fit. The headers on there now are hooker headers, but hooker is not listing any headers for the 360. Does anyone know where I can purchase headers for a 360 that will work in my '84?
'84 CJ7 w/'72 360ci, Edelbrock 650 cfm carb, T-176, Dana 300, 4" body lift, 2" shackle lift, 35x12.50 Baja Claws, needs painted but do too much damage for that to be economical.
studdmc is offline
post #2 of 9 Old 03-28-2002, 10:40 AM
Bulletproofcj7
Post
4wheel drove hardware and quadratec sell hedman brand headers that fit real nice, I've got a set of the hedman HTC (high tec coating)headers. they come with gaskets and all the hardware you need but i recomend buying copper gaskets from mr gasket,( for any brand header) they will save you loads of trouble down the road!
jason
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #3 of 9 Old 03-28-2002, 10:51 AM Thread Starter
studdmc
Post
Very excellent. Thanks for the information. Any idea bout how much those run? I am assuming the HTC is the best way go?
studdmc is offline
post #4 of 9 Old 03-28-2002, 11:08 AM
Bulletproofcj7
Post
They are expensive, around $300 or $360. or so.
Well worth it though if you are going to keep the jeep any length of time.
post #5 of 9 Old 03-28-2002, 09:41 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Post
Just a thought, you could always replace the headers with stock manifolds and still maintain the dual exhaust.They aren't as cool as headers but they rarely leak, are quieter, and almost never crack.Headers have minimal gains below 3500RPM's so depending on the type of wheeling you do,may not even be neccessary.
bazinga
jeepdaddy2000 is offline
post #6 of 9 Old 03-29-2002, 09:40 AM
4wheeler4CJ
4wheeler4CJ's Avatar
Arrow
Quick question:
I don't know what headers I have on my 360, I inherited the Jeep the way it is, LOL, but does the header have to come off to change the starter? Looks like it needs to, anyone have any trick? The header is so close, the starter looks trapped.
4wheeler4CJ is offline
post #7 of 9 Old 08-20-2010, 12:26 PM
tensley
1991 FSJ Wagoneer
I have put the Edelbrock Ceramic shorty headers on my Grand Wagoneer. It is a direct bolt on and was clear of everything(plug wires, starter, ect). It comes with everything you need and a nice warranty as well.
tensley is offline
post #8 of 9 Old 08-20-2010, 01:02 PM
fuzz401
1978 CJ7
the headers on the jeep do not go by engin size just amc -v8 ; all the AMc v-8 are the same size
your options are wheelwell or in frame headers or elderbrock makes shorty headers and last factory exhaust manafolds
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #9 of 9 Old 08-01-2011, 08:58 AM
78J10Owner
1978 J-Series Truck
to get the starter off on a J10 with headers...drop the bolts...and rotate the starter over the front shaft then give it about 1/4 to 1/2 turn and she will come right out between the frame and front shaft...or at least it does on mine...
78J10Owner is offline
What do these headers tell you? 84MSRB Jeep CJ Forum 4 05-22-2009 02:35 PM
headers, yay or nay? BlueFalcon Jeep CJ Forum 13 06-14-2007 07:58 PM
Headers for what? StewartCJ7 Jeep CJ Forum 2 06-12-2007 06:33 AM
304 Headers maxx9647 Jeep CJ Forum 1 05-24-2007 10:08 PM
304 Headers maxx9647 Jeep CJ Forum 2 05-24-2007 03:05 PM
