AMC 360 or Ford sb? - JeepForum.com
post #1 of 22 Old 04-28-2006, 07:38 PM Thread Starter
vladrulli
AMC 360 or Ford sb?
still not sure which engine to use in my CJ7...
I can't really find a decent AMC360 which doesn't require too much restoration work but I can get either a 302 efi or 351w efi...
the ford small block should bolt up to my t176 so adapting it to the drivetrain should not be an issue...
does anyone here have any experience with ford sb swaps? should I go for it or should I spend more time searching for a good amc?
also... how are the 360s on fuel? very poor milage or what? going to use the car as a daily driver so fuel consumption plays a big role... I know all v8 are fuel guzzlers but some are just a bit guzzlier than others...
vladrulli is offline
post #2 of 22 Old 04-28-2006, 08:37 PM
BLS33
Chief of the brain police
BLS33's Avatar
are you sure a ford engine will bolt up to a jeep transmission? i dont think it will i would think you would need an adaptor, but i could be wrong... i would go with an AMC v8 then you wont need all new mounts and possibly adapters, just need passenger side mounts and both block brackets, nice and easy swap
BLS33 is offline
post #3 of 22 Old 04-28-2006, 08:47 PM
BigYellaJeep
BigYellaJeep's Avatar
401 Baby!!
Alas, I only have a 304 at the moment. I'd do like BLS33 suggested, stick with AMC. I'm sure BESRK will differ however, lol.
Current Corvette: '01 Z06
Last Jeep: 98 Sport TJ
1st Jeep: '86 CJ-7 (I miss her)
BigYellaJeep is offline
post #4 of 22 Old 04-28-2006, 09:18 PM
hfjeff
hfjeff's Avatar
AMC without a doubt!! I am rebuilding a 360 as we speak.
MINE: 1995 YJ/2.5L/115K/Completely Stock
MY DAD's: 1978 CJ7/ AMC 360 .030" over/ Motorcraft 2100/ Edelbrock Performer/ Proform HEI Ignition/ Hedman Headers with dual Flowmaster 40's/ Taurus Fan/ FK-35 Control/ Painless Harness/ Rebuilt T150 & Dana 20/ 4" Lift/ 31" Procomp Mud Terrains/ All Fiberglass. (SOLD)
MY BROTHER's: 1996 ZJ Limited/5.2L/117K & Completely Stock.(SOLD)
hfjeff is offline
post #5 of 22 Old 04-29-2006, 02:52 AM Thread Starter
vladrulli
ford small blocks should bolt to the t176 without any adapter according to Novak:
http://www.novak-adapt.com/knowledge..._cj7_80-86.htm
I live in Iceland and I'm pretty sure that finding a decent AMC here is MUCH harder than in it is in the US...
post #6 of 22 Old 04-29-2006, 03:05 AM
mr_frenchy
Just go with the 304, easy to find, then do it up with the pro injection FI.
'75 CJ5, SOA, 36" buckshots, Warn 9000i upfront, 304 V8
In the Bible some where it says that if you sell your Jeep to buy a honda, you'll go to hell. It's somewhere in the back, near the maps.
mr_frenchy is offline
post #7 of 22 Old 04-29-2006, 02:51 PM
BLS33
BLS33's Avatar
I guess you're right 80-86 t176's will bolt right up, thats an interesting fact never knew that, you will still need the new mounts tho and those are pretty expensive...keep your eye out for an AMC 360 or 401 from an fsj they will be much easier to find then a 304, in my opinion at least
BLS33 is offline
post #8 of 22 Old 04-29-2006, 03:12 PM
geojeeper
IIRC the T-176 will bolt up to the Ford bellhousing, but the AMC bellhousing will not bolt up to the Ford block. In other words you'll need the Ford bh with the motor.
geojeeper is offline
post #9 of 22 Old 04-29-2006, 03:13 PM
JOKER4INK
I am putting an AMC 360 in my YJ as we speak. I got a grand waggy for basically nothing, so a good running motor was basically free for me. I like the Ford for a couple reasons though. I like knowing that there is a ton of aftermarket support for Ford motors. The fuel injection is a plus too! With the AMC, there is much less aftermarket support, making the performance parts much more expensive than a Ford or Chevy small block. I do like the AMC because AMC motors are what Jeep used. I say this, but knowing I am using a Ford tranny and tcase. Go figure
88 YJ...kinda. Clayton Hard Arms, V8, 1 tons running gear, twin sticked, Irok's, fuel cell, multi-colored
JOKER4INK is offline
post #10 of 22 Old 04-29-2006, 03:18 PM
MeCasa
Use whichever motor is available in Iceland. a 302 eats a LOT less gas than a 351, been running 351W's in my work trucks forever
I'd go 302 and hop it up if I needed more ponies, it's a good motor, almost as good at the 289 that came before it, torquee little bastard and good on gas, the 302 came about to make motors run on lower octane
Sex is dirty only if it's done right .... Live and Let Live .... Rules are Boring and I Don't Like Them
................................................ MeCasaEsSuCasa .................................
MeCasa is offline
post #11 of 22 Old 04-29-2006, 04:43 PM
bigmike0601
Im suprised there hasnt been more support for the chevy small block. They are easy to find and parts are cheap and also easy to find. I've got one in a cj5 and I get better mpg than a buddy who runs a 360.
bigmike0601 is offline
post #12 of 22 Old 04-29-2006, 04:46 PM
MeCasa
The 350 is the best generic motor on earth, but I believe it takes an adapter to go on a jeep, but then again, parts and help are a lot more common
It's definetely an option
MeCasa is offline
post #13 of 22 Old 04-29-2006, 05:17 PM
18to80DDC
Built Not Bought
18to80DDC's Avatar
I agree with the 350 swap, I have 360's in mine but parts and info are hard to find or expensive.
2001 4.0L Wrangler Sport - 3.5" lift on 33's
1973 CJ5 360 - 4" lift on 35's
1982 CJ7 360 - 2" lift on 32's
1971 Series III E-type Jaguar V12 - no lift...
18to80DDC is offline
post #14 of 22 Old 04-30-2006, 07:04 AM
amcjeepman
amcjeepman's Avatar
Until I saw the Iceland comment I would of course recommended the AMC/ Jeep 360 ( I am the amcjeepman after all) but I can imagine they would be a little harder to find there. So I'm going to go with a Small block Chevy, I wouldn't put a f*rd in anything.
James Belcher, Jr
Carolina Trailblazers PR
86 CJ7 401 TF999
81 CJ7 360 T177
05 Rubicon Unlimited
and others ;)
amcjeepman is offline
post #15 of 22 Old 04-30-2006, 07:14 AM
MeCasa
5 Hail Mary's
2 Our Fathers
Repent Ye Sinner Repent !!!
MeCasa is offline
Ford 302 dirt4900 Jeep CJ Forum 45 02-28-2010 06:45 PM
Ford T18 JOKER4INK Jeep CJ Forum 2 10-22-2005 02:55 AM
Need HELP with CJ-5 and Ford 302 mrnick Jeep CJ Forum 3 08-03-2004 06:05 AM
ford 8.8 in my 83 cj7 Big-L Jeep CJ Forum 2 05-30-2004 08:23 AM
EFI Ford 5.0 into my CJ NJCJ7 Jeep CJ Forum 6 05-06-2004 07:32 AM
