Quantcast AMC 360 Flex Plate - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > AMC 360 Flex Plate
Old 01-06-2007, 09:53 PM   #16
John N
1981 CJ8
Just a thought...bad torque converter? They have balance weights on them, too, but are not engine specific. Maybe you have a bad one that's out of balance.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline   Reply With Quote
Old 01-06-2007, 10:00 PM   #17
CJ-22
Could a bad torque converter cause a different vibration based on different flex plates? The 304 flex plate has a very mild vibration, but the 360 flex plate shakes the whole jeep pretty bad.
78 CJ-7, 360, 4 inch lift, 33" tires, 4.10 gears, TH 400 tranny, quadratrac t-case, dana 30 front, AMC 20 rear with Superior One Piece Axle.
CJ-22 is offline   Reply With Quote
Old 01-07-2007, 09:10 AM   #18
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Anything connected to the reciprocating assembly (crankshaft) that is out of balance can cause a vibration. If you go thru replacing/verifying all the external spinning stuff and it still vibrates, the next step might be yanking the whole spinning assembly and taking it to a machine shop that does engine balancing.. that would mean harmonic balancer, crank, rods, pistons, flexplate, converter and maybe even the crank pulley. I'd take it all and see what the machinist says..
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is online now   Reply With Quote
Old 01-07-2007, 12:31 PM   #19
CJ-22
WOW! That sounds a bit over my head. I wish I knew how to do all that, or had the time to do it. Maybe it is time for me to take it to a shop. Anyone in the So Cal area know a good diagnostic mechanic? I live in Corona.
Old 01-07-2007, 01:21 PM   #20
jpfaris
1979 CJ7
cj-22, Does the vibration occur when your in neutral or in gear or both?
jpfaris is offline   Reply With Quote
Old 01-07-2007, 01:34 PM   #21
CJ-22
It occurs all the time. I can't notice it as much while driving, but it is there. At idle it is just a very subtle shaking (kind of like the engine has a misfire), but at about 2000 rpms you can feel and hear it even better.
Glock Forum
