#1 | ||
AMC 360 Flex Plate
78 CJ-7, 360, 4 inch lift, 33" tires, 4.10 gears, TH 400 tranny, quadratrac t-case, dana 30 front, AMC 20 rear with Superior One Piece Axle. |
#2 |
GROUND POUNDER
![]() Join Date: Nov 2002
Wonder if someone didn't swap a 304 Harmonic Balancer onto the motor at the same time as the flex plate? Not sure how to tell the difference or if it's even possible but I would certainly check...
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 33s.. Ground Pounder Fab Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#3 | |
Chief of the brain police
Are you saying when it had the 304 balanced flexplate in there someone may have put a 304 harmonic balancer on as well and now that he's put a 360 balanced plate the harmonic balancer could be causing the vibration? Because thats something that I would think could cause it.
If there is sin against life, it consists in hoping for another life and in eluding the implacable grandeur of this life. People who don't like their beliefs being laughed at shouldn't have such funny beliefs.
#4 |
GROUND POUNDER
Yeah.. each size AMC engine should come with its own harmonic balancer/flywheel balanced for that engine. I believe though, that the parts will physically interchange so a 304 balancer could be bolted onto a 360. Now, if that 304 balancer were bolted on the same time a 304 flexplate were bolted on, it may not vibrate too bad.. (I don't know... just guessing). Then, when you swapped the correct 360 flexplate on, the difference in balance made it vibrate more. I would try to find the part number for the balancer and see if it's for a 304.. or maybe try to visually compare it to a balancer from a 360 to see if there's any major difference.
#5 |
That is a good idea BESRK. I assumed it had a 360 harmonic balancer all along. I'm going to check on it this week to know for sure.
#6 |
I have now located the part number to my harmonic balancer. It is 3230130. Does anyone know how to tell if this is to a 304 or 360? I have called numerous auto parts stores and checked all over the internet. I still do not know. Any help is appreciated.
#7 |
Bump.
How do you tell which balancer it is? I have found three different balancers online for 360's (none of the part #'s match) and I have found two different balancers for the 304 (none of the part #'s match). I don't want to change it unless I know it is wrong. Anyone know of a website that helps match jeep part #'s?
#8 |
GROUND POUNDER
Were you able to get the part number without taking the balancer or pulley off? If so, I may be able to climb around my 360 later on and look.. or even take pics of it to see if it looks the same (no big difference in counterweight...etc.).
If you haven't found the info by the weekend, I'll try to dig around in my shed.. I think I have a 360 balancer in there somewhere.
#9 |
Yes, you can get the number without pulling the flex plate. I had to turn the engine over a couple of times to get the number to the bottom so I could see it. I would really appreciate the help. I have called several places, but these flex plates are no longer available (except from aftermarket dealers, but the numbers are different).
Thanks for the help.
#10 |
Check your local Dodge dealer. You'd be suprised what is still available. That's where I got the flex plate and bolts for my 258 to TF999!
When you turn on your Jeep - Does it return the favor? '86 CJ7, 265 CI, DUI, TF999, Borla, Weber, 4" BDS Lift. |
#11 |
I got this # off of '72 core I have. Some of the balancing holes were drilled right through the number, so it might not be right.....3196525.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Warn XD9000i, etc...2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s............... |
#12 |
Okay, I finally found out what I have. My balancer is definitely a 360 balancer, but this puts me back with the same problem. Does anyone know why a 304 flex plate might vibrate considerably less than a 360 flex plate? I'm not an engine expert by any means, so excuse me if this is a dumb question, but could the engine have been rebuilt incorrectly to cause this? Could an internal 304 part been used instead of a 360 part?.
#13 |
Any 360 experts with advice? I don't know what to do next.
Should I assume the vibration is not related to the 304 flex plate?
#14 |
GROUND POUNDER
The tranny to engine bolts are tight right? I've had them loosen and cause vibes before.. I'm running out of ideas.
#15 |
Yes they are tight. I have changed the flex plate several times from 304 to 360 to test it and I had the vibration each time. I am wondering if there were two different flex plates for the 360 and I happened to buy the wrong one? I don't even know what year my 360 is. Maybe I have the wrong one and that is why it is vibrating so much. Does anyone know if there is a different flex plate for different year 360's?
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| TF999 and Flex Plate | VACJ7 | CJ Technical Forum | 4 | 08-11-2009 05:38 PM |
| which flex plate do I need | ctm | CJ Technical Forum | 3 | 06-27-2009 11:33 AM |
| Torque converter to flex plate bolt size? | CJ79-UK | CJ Technical Forum | 0 | 06-14-2009 03:37 AM |
| bad flex | 83 cj-7 258 | CJ Technical Forum | 12 | 06-15-2007 11:19 AM |
| Flex plate broke. Need Help! | CJ-22 | CJ Technical Forum | 8 | 01-23-2007 11:08 AM |
The time now is 09:45 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
