AMC 360 - Electronic Fuel Injection????? - JeepForum.com
post #1 of 37 Old 12-30-2009, 05:43 PM Thread Starter
oofrog
1981 CJ7
Is there a after market set up for the 360 to add EFI?
has anyone done it, and how have you found it?
oofrog is offline
post #2 of 37 Old 12-30-2009, 07:13 PM
jcal73
jcal73's Avatar
2015 JK Wrangler
These guys are going to do my chevy, they make kits for AMC as well
STOCK AMC TBI Complete System w/Distributor
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #3 of 37 Old 12-30-2009, 08:22 PM Thread Starter
oofrog
1981 CJ7
thanks for that.
Can someone explain the difference between EFI & TBI??
oofrog is offline
post #4 of 37 Old 12-30-2009, 08:46 PM
jfwireless
1976 CJ7
Originally Posted by oofrog View Post
thanks for that.
TBI, Throttle Body Injection is just one of the many types of EFI, electronic fuel injection.
Jim
jfwireless is offline
post #5 of 37 Old 12-30-2009, 08:47 PM Thread Starter
oofrog
1981 CJ7
ok thanks, what is the best, most reliable type for off road use?
oofrog is offline
post #6 of 37 Old 12-30-2009, 09:03 PM
duffer
1955 CJ3B
Assuming they are set up correctly, just about all offer a huge improvement in off road performance. I think you can generally caragorize EFI systems as either throttle body or port injection, with the latter divided between batch fired and full sequential. There is little difference between batch fired and full sequential at higher rpm, but the sequential does have an advantage at low rpm. About the only pit fall for the throttle body systems is that you can still have fuel/air separation issues because you still have a carb type manifold. The port injection does away with this problem. TBI systems are reasonably cheap while you can spend a whole lot of $ on a port injection system. Both will work.
duffer is offline
post #7 of 37 Old 12-31-2009, 08:23 AM
MontanaCJ5
1974 CJ5
One set-up I rarely see discussed here, perhaps due to cost, is Edelbrock's multi-point (port) fuel injection system. I have it, and it's the way to go. Expect to pay over $2500 as compared to Howell's throttle body system for a little over $1000. Alternately, you can do the "junkyard throttle body conversion" as discussed many times on other threads here.
Edelbrock.com - EFI - Pro-FloŽ2 EFI Systems - AMC
MontanaCJ5 is offline
post #8 of 37 Old 12-31-2009, 11:18 AM
Curt Reinhardt
1978 CJ5
BESRK has a Howell system on a 360.
Curt Reinhardt is offline
post #9 of 37 Old 12-31-2009, 12:28 PM Thread Starter
oofrog
1981 CJ7
the Edelbrock looks like the business, but have only seen it for $3k so far, where did you see it for $2500??
oofrog is offline
post #10 of 37 Old 12-31-2009, 01:08 PM
duffer
1955 CJ3B
The price bumped a bit about a year or two ago when the ProFlo went full sequential. I don't think the change probably incured any additional manufacturing costs doing so but guess we need to support those few companies still making things in USA. I bought the 35000 ProFlo II for the 3B for $2800 from my local engine builder (Internal Combustion Machine). A lot of money but it is still the most flexible system I have seen. There is a learning curve but there is just about nothing it will not do (except maybe pass the smog guys). After a simmering 35 year battle with Holleys and complete rejection of the Edelbrock carbs, it is pure, unadulterated pleasure. Don't like something? Just toggle down a few menus and change it-on the fly.
duffer is offline
post #11 of 37 Old 12-31-2009, 06:36 PM Thread Starter
oofrog
1981 CJ7
how much difference do you think it will make to my rebuilt AMC 360???
oofrog is offline
post #12 of 37 Old 12-31-2009, 08:06 PM
duffer
1955 CJ3B
That depends on what else you have done to it. What it will do is eliminate any hacks or studders, even upside down (at least until it runs out of fuel because the tank pickup is sucking air), and allow you to maximize the performance however the engine is set up. You probably will get the biggest kick if you have at least an RV type cam and some decent compression as most versions flow pretty well. Again, a lot of money. Would I buy another? Absolutely! Most fun I have ever had playing with the tunning. No gas to drain to change jets, no cams, needles, or springs to change, no gaskets to replace, no advance curves to alter-just a few keystrokes and it is all done.
duffer is offline
post #13 of 37 Old 01-01-2010, 07:35 AM
John N
1981 CJ8
That's what I have, too.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #14 of 37 Old 01-01-2010, 11:12 AM
CJ5Doc
1975 CJ5
Has anyone tried this.... Powerjection 3
Professional Products Online
CJ5Doc is offline
post #15 of 37 Old 01-22-2010, 09:40 AM
Agar426
1974 CJ6
I'm curious about this one as well
Agar426 is offline
Bad TBI electronic fuel pump or problem with fuel tank? boomvader Jeep CJ Forum 5 01-18-2010 10:26 PM
Fuel Sending Unit and Fuel Injection Question CJman77 Jeep CJ Forum 4 12-21-2009 05:01 PM
fuel injection here i come dirtydaddy Jeep CJ Forum 5 01-10-2009 10:36 AM
fuel injection kit KINGJRK1974CJ5 Jeep CJ Forum 4 02-20-2008 10:34 AM
Electronic Fuel Pump mjp83 Jeep CJ Forum 1 04-27-2007 09:10 PM
