AMC 360 / Edelbrock Carb and Intake Questions - JeepForum.com
post #1 of 6 Old 12-09-2010, 11:29 AM Thread Starter
aaronjwood
1978 CJ7
I have a 1978 CJ7 with an AMC 360 engine, Edelbrock Performer 600 CFM carb (part# 1406), Edelbrock Performer AMC intake, T150/Dana 20, stock ignition Module with an e-core coil and a distributor with a larger cap setup (I suppose this is similar to the team rush upgrade, but not sure if it was done 100% correct). By the sound of the engine at idle I believe that there is an aftermarket cam installed. I have no idea what it is.
I have had the Jeep for about 2 months and after reading within this forum for countless hours have some questions.
1. Is this the correct size carb for this engine?
2. What gains could I expect by installing a CDI ignition?
3. Will installing the Edelbrock "heat shield" gasket improve warm starts?
4. Is the stock spring/metering rod setup adequate or should I attempt to tinker?
Thanks to all who advise?
--Aaron
aaronjwood is offline
post #2 of 6 Old 12-27-2011, 04:25 AM
ARTIZAN
1973 FSJ Wagoneer
What's wrong with your warm starts now?
Maybe you can do a title search at the DMV to find the previous owner and see if they know about your engine.
If it isn't a stock cam it's prabably an RV cam. There aren't many options for low end performance which is what you would want in a jeep. And with that, the performer is a good intake and it calls for the 1406 carb.
ARTIZAN is offline
post #3 of 6 Old 12-27-2011, 07:46 AM
GP_Pete
Aaron
Ive been running the same edelbrock performer package (to include cam and lifters) for around 10 years now. I run a full msd ignition (6al box, blaster2 HV coil, msd wires). Stock autolite plugs. I also put on the bigger rotor cap-adapt by msd.
Very happy with the setup. The carb needs to be reworked for better offroading or a different one put on. A project for another time.
Go through your old ignition system and inspect everything. Test it too.
GP_Pete is offline
post #4 of 6 Old 12-27-2011, 08:04 AM
bigredisb
1979 CJ7
I run the same setup as well. The 600 is plenty adequate for the 360 in my opinion. I also had hot start challenges with my setup and installed a edelbrock wood 1 in spacer. I have never had a hot start issue again since and the wood is super tough.
I did end up messing with my metering rods and stayed with the stock size rods but went up one spring to to the pink spring. and I also added the off road needle and seat kit.
As far as ignition I love the MSD 6AL I put in. I noticed that my throttle response was improved quite a bit.
1979 CJ7 aka "Christine" Build Thread:
2013 Rubicon Unlimited build thread:
bigredisb is offline
post #5 of 6 Old 12-27-2011, 08:15 AM
GP_Pete
Not trying to hijack the thread - maybe info would help OP as well - bigred, how has the 600 performed with the offroad needle, etc?
GP_Pete is offline
post #6 of 6 Old 12-27-2011, 08:33 AM
bigredisb
1979 CJ7
Much better than stock. Its a bit rough and occasionally stalls if you try to let it idle at a really steep angle. When I say steep I mean rear bumper just barely touching the ground while the front is in the sky.
For faster rougher stuff I noticed a huge difference.
clifford intake with holley carb questions c-dogg Jeep CJ Forum 30 11-14-2014 05:01 PM
cj-7 360 edelbrock aluminum heads, air gap intake, cam, 750 carb. GOOD COMBO? '69DART383 Jeep CJ Forum 7 10-04-2011 04:59 PM
Edelbrock 4rb intake? kmm Jeep CJ Forum 2 11-22-2010 06:47 PM
Edelbrock Carb Krackalacka Jeep CJ Forum 4 06-01-2009 09:15 PM
Carb/ intake Gasket Questions HavaCJ Jeep CJ Forum 2 01-17-2008 12:59 AM
