AMC 360 dipstick reading says overfilled, with 3.5 quarts.... - JeepForum.com
post #1 of 5 Old 04-28-2013, 07:49 AM Thread Starter
AJI
1979 CJ5
As the title says, my dipstick says overfilled, but I know this engine takes at at least 5 quarts. I'm positive I drained out the previous oil, there were easily 5 quarts that came out. Any ideas?
Thanks
AJI is offline
post #2 of 5 Old 04-28-2013, 08:23 AM
roadhog304
1973 CJ5
IS the dipstick tube all of the way into the block? You might check that first. Is it a factory dipstick or a aftermarket? I have an aftermarket that I need to remark because it is not right. My dipstick says full with 7 quarts in it and I know that is not right but I do run six quarts in it.
1973 Jeep CJ5 Amc powered resto-mod
1976 Jeep CJ7 GM powered future 1 ton crawler
roadhog304 is offline
post #3 of 5 Old 04-28-2013, 11:03 AM Thread Starter
AJI
1979 CJ5
Yeah it is all the way in. I'm pretty sure the dipstick is stock, ill post a picture in a few though because I don't have anything to compare to, maybe someone can spot a difference.
AJI is offline
post #4 of 5 Old 04-28-2013, 11:12 AM
Ivehad4
1978 CJ7
I've had oil settle into the dipstick tube, probably where it bends at the bottom of the block. I've used light puffs of compressed air to clear it and then it reads correctly.
1978 CJ7 304/T150
1959 Willys CJ5 F4/T90
1995 XJ 4.0
1998 TJ 4.0
Ivehad4 is offline
post #5 of 5 Old 04-28-2013, 02:18 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Dipsticks are interchangeable. It is entirely possible that the old one broke sometime in the past and the PO simply grabbed another off ???.
You can completely drain and refill the crankcase with the prescribed amount of oil. Then dip the stick and mark the correct level.
jeepdaddy2000 is offline
