Amc 360 cant keep cool - Page 3 - JeepForum.com
post #31 of 36 Old 09-02-2012, 11:07 PM
Mike78cj7
1978 CJ7
Sounds like you need to confirm gear ratio. 3,300 to 3,400 at 62-64 MPH is really high RPM's if you say you have 33" tires and 4.56 gears
1978 cj7 304 t176
1983 cj7 258 t4
Mike78cj7 is offline
post #32 of 36 Old 09-10-2012, 07:29 PM
tevans59
1979 CJ7
I dont have much to offer but I disagree with the one that said 4.56 was not a low gear, but in my day 4.56 and 4.88 were racing gears and I would not want my jeep to be screaming thru the gears, mine is loud enough as it is , that would be like driving in 3rd all the time. good luck man
tevans59 is offline
post #33 of 36 Old 09-10-2012, 08:09 PM
OldTexas
Just an off thought, have you replaced the coolant with a 50/50 mixture of water and ethelyne glycol (anti-freeze)? If it's straight water, 100% coolant, or old coolant, those will reduce your cooling capacity.
May want to take a good look at your fan clutch too. It needs to be between free enough to idle at highway speeds so as not to create an air dam and tight enough to pull air at lower speeds and when idling. When you say "heavy duty fan clutch" that concerns me a little bit.
Is there any indication the PO had pulled the heads for a vlave job? It may sound silly but I've seen reversed head gaskets block water jackets.
If you haven't already, a really really good cooling system flush might be a good idea. It can be amazing what some people can put in their radiators sometimes.
Finally, check the pressure on the radiator cap and be sure it is correct for your 360. Too high a pressure cap will not permit the heated coolant to expand into the overflow and coolant, the higher the pressure, becomes less and lkess effective at dissipating heat.
Paved roads, another example of government waste!
OldTexas is offline
post #34 of 36 Old 09-10-2012, 08:45 PM
mike_breaker_5
this is no joke. i had an hour long argument with a co-worker about putting salt in the radiator in the winter time. no crap, this guy was having similar problems with his 4.0 2door Cherokee. he said it was overheating very easily. since i'm known as the jeep guy at the plant he came to me.
i asked him similar questions as all of you. then he told me he uses salt in the winter to keep the water from freezing. after i picked my jaw up off the floor i told him to flush the coolant system immediately. he reported back that it didn't work, then proceed to show me a picture of the coolant ports under the head in a pic on his phone the next day. there was a little bit of cylinder head left in his chunk of rust.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #35 of 36 Old 09-11-2012, 10:55 AM
turbogus
1978 CJ5
Semper Fi, Old Texas. I like your Ronald Reagan quote.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #36 of 36 Old 09-11-2012, 06:57 PM
OldTexas
Semper Fi...
Down here a lotta folks will put pepper in their radiators as a temporary way to stop a leak.
OldTexas is offline
Cool Rat Rod DJ !!! mopar408 Jeep CJ Forum 1 02-09-2012 03:48 PM
Cool CJ MoC Jeep CJ Forum 2 07-17-2011 03:55 PM
COOL or NOT? bigHeadMarine Jeep CJ Forum 18 03-19-2010 12:18 AM
To Cool tumbleweed58 Jeep CJ Forum 3 02-23-2008 10:26 AM
Way Cool MeCasa Jeep CJ Forum 6 06-08-2006 12:11 AM
