AMC 304 Water Pump - JeepForum.com
post #1 of 12 Old 03-09-2011, 09:45 PM Thread Starter
rrtex1
1981 CJ7
AMC 304 Water Pump
Anyone have steps to replace water pump on a 304? Just want to make sure I am not missing anything.
Round Rock, Texas
1981 CJ7 AMC304
rrtex1 is offline
post #2 of 12 Old 03-10-2011, 05:40 AM
BioTex
1979 CJ7
1. Drain the radiator.
2. Loosen the P.S. Pump and alternator. (to loosen belts)
3. Remove fan shroud.
4. Remove fan.
5. Remove pump pulley.
Take pictures up close of all bolts and spacers.
6. Unbolt the pump.
7. Clean mating surface.
8. Chase all threads.
9. Use RTV on new gasket.
10. Reinstall.
Pretty straight forward as long as the "might as well's" don't get you!
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #3 of 12 Old 03-10-2011, 09:04 AM
mopar408
1974 CJ5
FWIW. I had a problem w/ overly-large/thick casting on BFN cast iron water pump at bottom hitting top of harmonic balancer. Check that before installation by putting it together w/ 3 or 4 bolts and no gasket and turning it thru. If
you need to, 2 minute job w/ Makita on a bench. Took me half a day 'cause I had it completely together, cleaned up and pretty
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
post #4 of 12 Old 03-10-2011, 10:15 AM
ejschmitt
I recently replaced mine with a flowkooler aluminum pump and went as BioTex described. Should not be a big deal, unless you find some broken bolts to extract in the timing chain cover like I did...
ejschmitt is offline
post #5 of 12 Old 03-10-2011, 02:03 PM Thread Starter
rrtex1
1981 CJ7
Can I go cheap and get a reman pump? Suggestions?
Round Rock, Texas
1981 CJ7 AMC304
rrtex1 is offline
post #6 of 12 Old 03-10-2011, 02:11 PM
Curt Reinhardt
1978 CJ5
Nothing wrong with the pump below unless you're doing something very unusual...
http://www.napaonline.com/Search/Det...+50038+2038003
Curt Reinhardt is offline
post #7 of 12 Old 03-10-2011, 02:32 PM Thread Starter
rrtex1
1981 CJ7
Thank you Curt.
The reason I was looking at replacing it was I have a leak but my leak seams to be where the timing chain cover connects to the block and not where the pump connects to the timing chain cover. Maybe I don't need a pump. What extra has to be done to remove the timing chain cover as well and replace that gasket?
Round Rock, Texas
1981 CJ7 AMC304
rrtex1 is offline
post #8 of 12 Old 03-10-2011, 02:45 PM
LSUtiger
1980 CJ5
I have to take the power steering pump and alternator completely off.
Also 2 of the last 3 that I replaced hit the vibration dampner and the pump had to be shaved a little.
To take the timing cover off, all that's left after the waterpump is the vibration dampner, distributor and fuel pump.
1980 cj5 401, t-176, p/s., YJ p/b, tfi/hei hybrid, 3.73 30/44
LSUtiger is offline
post #9 of 12 Old 03-10-2011, 02:47 PM
BioTex
1979 CJ7
Quite a bit more. You need to pull the harmonic balancer, the timing gear set, and the fuel pump. You should lossen the front oil pan, and install a new timing cover crank seal.
While you are in there, you will want to replace those timing gears, and might as well replace/rebuild the oil pump.
Then there are those pesky bolts that strip out of the aluminum cover. I install studs in their place.
Then you will find the cover has eroded away on the inside where the water pump impeller rides. You will end up ordering a new cover...
Bene there done that several times now. Have fun!
Currently:
BioTex is offline
post #10 of 12 Old 03-10-2011, 02:50 PM
Curt Reinhardt
1978 CJ5
Thank you Curt.
If you go that far you may also want to replace your timing chain - hope this helps from my 78 FSM. Take care - Curt
post #11 of 12 Old 03-10-2011, 05:48 PM
mopar408
1974 CJ5
and my post # 3.
Check it GOOD on a test fit before you get very far.
If you pull the T/C be SURE you inspect cam gear and fuel pump cam lobe for wear since you've probably seen the horror stories.On second thought, it'd almost be worth it to look for that reason alone.
mopar408 is offline
post #12 of 12 Old 03-10-2011, 06:33 PM Thread Starter
rrtex1
1981 CJ7
Thank you! More than I want to chew off.
Round Rock, Texas
1981 CJ7 AMC304
rrtex1 is offline
water pump on 258 ltbill Jeep CJ Forum 3 07-24-2010 05:36 PM
To fix or not to fix? Water pump or water pump, steering box leak and heater core? brussell Jeep CJ Forum 3 04-18-2010 11:03 AM
SBC Water Pump Ocedek Jeep CJ Forum 20 01-08-2010 06:27 AM
Misc. 79 CJ7 Brake, water pump and PS pump ques. 2Xtreme Jeep CJ Forum 9 12-03-2009 05:44 AM
New water pump in 86 cj7 mmerlina Jeep CJ Forum 2 11-28-2007 09:11 AM
