Amc 304 Tuning Help - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Amc 304 Tuning Help
Custom Axle Work at CCORRough Country Lift Kits and Parts!Swag Off Road BIG-HIT TJ-YJ Rear Bumper
Unread 09-20-2014, 09:05 PM   #1
Hbryant123
1979 CJ7
Amc 304 Tuning Help
I rebuilt my amc 304 myself last winter, now i want to tune it in run good and smoothe. The carb is an mc2100 from a ford with 1.08 venturis. I am running an HEI distributor. The engine starts and runs decent but the idle isnt smoothe but its not like a vaccum leak either. I always wanted to have a smooth running older v8. I am not sure wear to start, the carb is kinda unknown and i did use the origional rockerarms, pushroods and bridges. Where should i start in tuning my engine in?
Hbryant123 is offline   Reply With Quote
Unread 09-21-2014, 06:35 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Did you set the idle mix screws for the 'best lean' mix? Is the choke opening all the way?
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Unread 09-21-2014, 07:03 AM   #3
lucdog
lucdog's Avatar
1980 CJ5
How does the exhaust sound, do you detect a miss, or does it sound normal?
How does it run off the idle circuit at 1400 rpm, does it smooth out?
1957 WILLYS pickup, needs work.
1973 J 4000,
1978 CJ7 DD.
1979 CJ7 360, TH400/Quadratrac trail Jeep.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7 pretty weekend and sometimes to work Driver in the summer, My first rebuild, if the Q-trac and 5 are broke, this one is the one to take. its just as capable as the other 2, except nice paint.
1984 Grand Wagoneer, 1 ton axles, great 360/727, and a big a$& tree fell on it .
1989 YJ the CJ to YJ conversion.
2005 TJ Rubicon.
2011 Grand Cherokee Laredo 4x4, Mrs. LUCDOG's DD.
Lots of parts not for sale, i'm a hoarder.
lucdog is online now   Reply With Quote
Unread 09-21-2014, 07:05 AM   #4
swatson454
Mall-crawlin' Hot Rodder
swatson454's Avatar
1983 CJ7
Personally, I'd start at the spark plugs and work my way backwards, through any emissions components that you have and finally to the carb.
*Check the condition of, color and gap of the spark plugs.
*Carefully inspect the plug wires, especially around the exhaust.
*Inspect the inside of the cap for evidence of arcing on the plastic and welding on the posts, especially if you have aluminum posts.
*Check the rotor for red dust. If you've got it, pull the rotor off and make sure you haven't welded the advance mechanism together. Address as needed
*Check the PCV and EGR and for vacuum leaks on anything that hooks to vacuum either directly or indirectly.
*Make sure you're using the correct fuel filter (if bypass type, orient the bypass at 12 o'clock)
*Blow out any air bleeds in the carb with carb cleaner.
*Check the float level.
*Fire it up and make sure the choke pulls completely off when warm.
*Once warm, make sure the timing is set between 8* and 12*, run through the lean-best idle procedure and see where you stand.
Shawn
Ps: Although I've tried to lay this out in an orderly, step-by-step fashion, the addition of beer in between any or all of the steps is perfectly acceptable.
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline   Reply With Quote
Unread 09-21-2014, 10:03 AM   #5
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Shawn
Which is why it will NEVER run right....
If you follow alll the above instructions and you can't get to idle right, you woill want to drop the cover on the power valve and check to see if there is any gas in it. If so, the valve is bad and will need to be replaced.
jeepdaddy2000 is offline   Reply With Quote
Unread 09-21-2014, 10:46 AM   #6
swatson454
swatson454's Avatar
1983 CJ7
Good point
Unread 09-21-2014, 08:42 PM   #7
Hbryant123
1979 CJ7
Thanks for the replies! I have one more questions before getting my hands dirty, I am wondering what the vaccum is supposed to be for this engine? I believe I checked it and it was at 13.
Unread 09-21-2014, 08:44 PM   #8
Hbryant123
1979 CJ7
When the engine is warm and idling it sounds great at the tail pipe, very uniform and smothe. Idle accerlerates pretty well. no hickups or miss
Unread Yesterday, 12:33 AM   #9
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
At your elevation 18-20" would be normal. 13" is way low.
Matt
Matt1981CJ7 is offline   Reply With Quote
Unread Yesterday, 09:24 AM   #10
Hbryant123
1979 CJ7
Matt
I agree. My worn out s10 held steady at 19. I had two different intakes and two different carbs. No matter what i never saw vaccum at 18-20. Could valves not opening up all the way cause low vaccum? During the rebuild i reused my push rods, rocker arms and bridges.
Unread Yesterday, 12:12 PM   #11
RedNeckCorvette
1979 CJ7
Matt
Air leak?
RN
RedNeckCorvette is offline   Reply With Quote
Unread Yesterday, 12:23 PM   #12
zillla
1975 CJ5
My 304 gets 14 on a good day.. No more.. I live at 6500" so I think it's normal.
FYI: I had 2 different 2100's on my 304. The first was a 1.08. Ran OK but seemed to lack a bit. Upon recommendation of a carb guy I traded for a 1.21. Much better.. IMO the 1.08 is a tad small on a 304..
Pull my finger
zillla is offline   Reply With Quote
