AMC 304 to a T86 - JeepForum.com
post #1 of 14 Old 09-29-2014, 03:40 PM Thread Starter
DLord5
1966 CJ5
AMC 304 to a T86
Hi all! When I bought my '66 cj5 the previous owner had taken out the buick V6 and put in a chevy 4 cylinder. I want to put in my 304 out of my '74 cj5. I am not into hard 4 wheeling, just trail driving with the kids, will I have to change the trans, or transfer case?
DLord5 is offline
post #2 of 14 Old 09-29-2014, 03:54 PM
swampbuddy
1983 CJ7
What transmission do you have in it?
I found out about Jeeps late in life, so now I have to play catch up and get as many as I can. Man, life is great
swampbuddy is offline
post #3 of 14 Old 09-29-2014, 04:09 PM Thread Starter
DLord5
1966 CJ5
In the '74 I have the T15, with a Dana 20 transfer case. "66, T86 with a Dana 18 transfer case. I will just swap the whole deal if that is an option! Wasn't sure if I would have mounting issues. I hope I do not sound like a moron, I just have limited experience with swaps.
DLord5 is offline
post #4 of 14 Old 09-29-2014, 04:35 PM
swampbuddy
1983 CJ7
According to Novak, a T86 doesn't bolt up to an AMC motor
http://www.novak-adapt.com/knowledge/t86.htm
Not sure how everything will bolt in to a 66', I never been lucky enough to own or wrench on one.
Take some measurements and see how things line up and fit. Keep an eye on the fan clearance at the radiator and the front driveshaft location and placment (make sure it won't hit anything)
Next best thing is do a Google search for a AMC V8 swap for a 66' CJ, I'm sure there is someone out there that has done it or tried to do it.
What about going back to the V6? It should be a direct bolt in.
post #5 of 14 Old 09-29-2014, 04:36 PM
CSP
Pretty sure that your biggest issue is going to be fitting the AMC V8 in a front clip that's 5" shorter than the one it's coming out of.
CSP is offline
post #6 of 14 Old 09-29-2014, 04:38 PM
swampbuddy
1983 CJ7
What if he went to an electric fan?
post #7 of 14 Old 09-29-2014, 04:40 PM
CSP
Maybe that's a possibility.
Just judging from the questions the OP has asked I'm not sure he's even aware that the '71 and older engine compartments are smaller.
CSP is offline
post #8 of 14 Old 09-29-2014, 04:46 PM
swampbuddy
1983 CJ7
I wasn't 100% sure either.
I just hate to see a AMC motor go to waste. For some reason you can't find new ones anymore
post #9 of 14 Old 09-29-2014, 05:06 PM Thread Starter
DLord5
1966 CJ5
Thank you all for your replies! I have thought about going back to the V6, but like was said I don't want the 304 to go to waste. I am not familiar at all with the '66. Just saw the difference is steering... The '74 isn't going anywhere, so I will be sure not to let anything go to scrap. Geez, I didn't know about the front clip either... I think I have lots of research to do before I swap anything! Anyone know where I can get another dauntless V6? I posted a thread about swapping my Dana 27 with the Dana 30 that came out of my '74. Any opinions about that, or should I wait on the other thread? Thanks again all!!
DLord5 is offline
post #10 of 14 Old 09-29-2014, 05:09 PM Thread Starter
DLord5
1966 CJ5
I thought it looked smaller, but I thought it was just because of the motor!
DLord5 is offline
post #11 of 14 Old 09-29-2014, 05:29 PM Thread Starter
DLord5
1966 CJ5
I just saw online that there is no adapter to mount the t86 to any AMC engine. Would this trans then bolt to any Chevy V6? I found a 2.8 for cheap, and am now thinking of going that route...
DLord5 is offline
post #12 of 14 Old 09-29-2014, 05:29 PM Thread Starter
DLord5
1966 CJ5
DLord5 is offline
post #13 of 14 Old 09-29-2014, 05:38 PM
BlueRubiconrich
Ok you got the 304 get a Jeep T18 and the Dana 20 or Scout 300.
and build a 72-CJ7. Your 66 frame is C channel to much work to put the 304 in that. Or drop a 231 even fire V6 in to the 66 call it a day.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #14 of 14 Old 09-29-2014, 06:54 PM
CSP
Look at where the back side of the front fenderwell opening ends on each one for a comparison. It will be very obvious looking at both of them.
CSP is offline
