AMC 304 Rebuild Intake Manifold White Smoke - JeepForum.com
post #1 of 35 Old 04-07-2013, 02:13 AM Thread Starter
Greekcj5
1973 CJ5
All,
I recently rebuilt my 72 AMC 304, but when I started it back up, even though it started right up, I have quite a bit of white smoke coming out from the rear hole of the Edelbrock intake manifole I have on it. Is this something normal or am I in for a surprise?
Greekcj5 is offline
post #2 of 35 Old 04-07-2013, 07:26 AM
OleBlue73
1973 CJ5
Originally Posted by Greekcj5
All,
The hole where either the PCV valve or the EGR valve (if equipped) goes?
1973 CJ5, 304, T15, D20
2009 JKU, Rubicon
2005 TJ, X, 4.0, 6 speed
OleBlue73 is offline
post #3 of 35 Old 04-07-2013, 01:05 PM Thread Starter
Greekcj5
1973 CJ5
This is the hole. I don't think anything was there when i took it apart.
Greekcj5 is offline
post #4 of 35 Old 04-07-2013, 01:08 PM Thread Starter
Greekcj5
1973 CJ5
Not sure why it looks like something is in the hole but here's another to give a better idea of what I'm talking about.
Greekcj5 is offline
post #5 of 35 Old 04-07-2013, 01:32 PM
Caish
1987 XJ Cherokee
Looks like a Crankcase vent of some kind goes there.
http://www.ebay.com/itm/EDELBROCK-RB...p2047675.l2557
Completed auction of an intake.
But you can see on it there is a bung that goes in that hole and a PCV valve goes there, that is normally on a valve cover of other engine makes.
Join us on Jeeperz Creeperz on Google+
Facebook: Arkansas Jeeps
Caish is offline
post #6 of 35 Old 04-07-2013, 02:02 PM Thread Starter
Greekcj5
1973 CJ5
Holy cr@p I've had this Jeep for almost 2 years now but the PO never had anything in that hole so i assumed it was supposed to be open. What about the white smoke though? I barely drove it before the engine rebuild because of a pretty bad oil leak from the rear main seal so i don't know if it was smoking before. Isn't white smoke a sign of coolant burning?
Greekcj5 is offline
post #7 of 35 Old 04-07-2013, 03:18 PM
jumbojeepman
1976 CJ7
That's the hole for the PCV. Probably oil smoke coming out of it, definitely needs a PCV in there.
jumbojeepman is offline
post #8 of 35 Old 04-07-2013, 03:50 PM Thread Starter
Greekcj5
1973 CJ5
Awesome. I'll find one online and install it then. Thanks gents
Greekcj5 is offline
post #9 of 35 Old 04-08-2013, 05:24 PM
Hurricane4
PVC Grommet J4006019
The unbelievable we can do immediately . . . the impossible just takes a little longer.
Hurricane4 is offline
post #10 of 35 Old 04-08-2013, 05:36 PM Thread Starter
Greekcj5
1973 CJ5
Thanks orange.
Greekcj5 is offline
post #11 of 35 Old 04-08-2013, 06:26 PM
Caish
1987 XJ Cherokee
When you first start it, if your seeing white smoke, it could just be normal condesation vaporing out of the cold engine and should clear up shortly.
If the oil is not milky and I wasn't loosing coolant not sure I would worry to much about it.
Caish is offline
post #12 of 35 Old 04-08-2013, 06:42 PM Thread Starter
Greekcj5
1973 CJ5
I ran it for about 25 minutes and the smoke kept coming. I actually drained the oil after i ran it cause i noticed a small oil leak from a pinched seal and the oil looked good. The engine did take me a few months to put back together and with the winter i could understand the moisture but i never thought it would smoke like that that or smoke that long.
Greekcj5 is offline
post #13 of 35 Old 04-08-2013, 06:47 PM
ASteve
1972 CJ5
Greek,
I have the same year and engine. Make sure you get the right PCV as they are tuned for the engine they sit on. Also, that rubber grommet is no longer made, but this one fits....http://www.summitracing.com/parts/rnb-42056
ASteve is offline
post #14 of 35 Old 04-08-2013, 06:58 PM Thread Starter
Greekcj5
1973 CJ5
Thanks Steve. I'll probably order the valve and grommet tonight and try to start it back up this or next weekend and see how it does with the valve. I looked real quick for the valve but all i saw were forum threads about it. Anyone know off the bat who sells it?
Greekcj5 is offline
post #15 of 35 Old 04-08-2013, 09:13 PM
tchimmerroks
1983 CJ5
Originally Posted by Greekcj5 View Post
All,
Years ago I owned a '78, 304 equipped CJ5. The fuel/emissions was all stock and I recall the PVC had a vacuum hose that connected to a vacuum source at the carburator. I would double check the vacum diagram for your year Jeep however.
tchimmerroks is offline
