AMC 304 mpg - JeepForum.com
post #1 of 15 Old 01-09-2010, 03:55 PM Thread Starter
Viencent
1982 CJ7
AMC 304 mpg
what is good mpg for a 304 with 33 tires, just filled up the new jeep and got about 12 mpg, combo highway/city. also any good tips for this Engine like the nutter?
Viencent is offline
post #2 of 15 Old 01-09-2010, 08:25 PM Thread Starter
Viencent
1982 CJ7
bump...any pointers at all for this 304?
Viencent is offline
post #3 of 15 Old 01-09-2010, 09:19 PM
4Huskrs
I have a 304 and I do not get very good mileage.
Ron
76 Jeep CJ5
68 Chevy C-10
4Huskrs is offline
post #4 of 15 Old 01-09-2010, 09:44 PM
Pathkiller
1974 CJ5
No such thing as a Nutter for AMC V8's as they never used the computer controlled carb. Best you can do is a good tune up and drive it sensibly.
Pathkiller is offline
post #5 of 15 Old 01-09-2010, 10:37 PM
semikrazy
1977 CJ7
I had a 304 in my '75 and it never got less than 20mpg. It was mostly stock only had a mild cam and headers with a 2100 carb running 32" Firestone ATX. Of course it was when gasoline was gasoline. My '76 with the 258 gets way worse fuel mileage, around 15mpg.
semikrazy is offline
post #6 of 15 Old 01-10-2010, 04:28 AM Thread Starter
Viencent
1982 CJ7
Thanks for the input, so anyone got some tips for this 304? things to watch for or upgrade?
Viencent is offline
post #7 of 15 Old 01-10-2010, 05:47 AM
Area.3.Fiftyone
Originally Posted by Viencent View Post
thing to do with a 304 for an upgrade?
Buy or borrow one of these:
And then do this:
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #8 of 15 Old 01-10-2010, 05:54 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Cute but I think here is a better ignition system I believe or the 304.
Search for JeepHammer post on the subject.
Funny thing is, there is a member on here with an 8 sec 1/4 mile CJ and he get 14 mpg with that V8.
John Strenk is offline
post #9 of 15 Old 01-10-2010, 06:36 AM Thread Starter
Viencent
1982 CJ7
thanks fond JeepHammers post and it has some great info, wil be doing that upgrade soon
Viencent is offline
post #10 of 15 Old 01-10-2010, 06:44 AM
jfwireless
1976 CJ7
My stock 1976 CJ-7 with a 304 only got around 10-12 MPG before the TBI conversion, that really helped, now around 18 mpg. But I am running a TH400(very heavy internally) and a full time QT transfer case. If it was not for the drive train most likely would get over 20 mpg. My 304 is getting tired, compression down to around 110-130 lbs on all 8 cylinders, but still running very strong with the junkyard TBI conversion. I have a 360 I have been working on for a long time, hopefully when I get that complete we will see how the junkyard TBI conversion works on a mechanically sound engine. I am looking forward to that day. It will be optimized with a special ground camshaft for TBI operation. That should help significantly.
My axle ratios are stock 3.54, and running 31 inch Dueler HT tires.
Jim
jfwireless is offline
post #11 of 15 Old 01-10-2010, 07:11 AM
halpeters
1978 CJ7
I have a stock 78 cj-7, 304, 3 speed, 3.54 axles, with 31" M/T's and get around 12-15 MPG, with current pump gas "up to 10% ethenal" stuff...
My odometer reads about 8% low due to larger tire size over stock. Be sure to take tire size into consideration when calculating gas mileage.
1978 CJ-7
halpeters is offline
post #12 of 15 Old 01-10-2010, 07:18 AM Thread Starter
Viencent
1982 CJ7
didnt think about tire size. so whats the ratio for 33's?
Viencent is offline
post #13 of 15 Old 01-10-2010, 07:23 AM
BioTex
1979 CJ7
My stock 304 (except an RV Cam) with MC 2150, 33's and 4" lift gets 14-15mpg.
I have 3.31 gears.
I have the Team Rush upgrade.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is online now
post #14 of 15 Old 01-10-2010, 05:14 PM
halpeters
1978 CJ7
Well, that depends - larger tires can have a lot of variation between brands, style, and wear.
The best way is to use a GPS. Most have a setable trip meter. On your next road trip, write down your odometer reading, and zero the trip meter. At the end of your trip divide GPS miles by odometer miles. This will give you the adjustment factor. Be sure the GPS doesn't loose lock - no woods trip for this...
Or, you can use MPH - drive at 60 MPH on the speedo, and see what the GPS says - same formula - GPS MPH divided by speedo MPH = adjustment factor.
For to figure out true miles driven, take your odometer miles and multiply by the adjustment factor.
For my Jeep with 31's the adjustment factor is 1.08.
Hope that helps,
Hal
1978 CJ-7
post #15 of 15 Old 01-10-2010, 06:41 PM
h2ojeep
1978 CJ7
When I first got my CJ7 304, 354 gears, 31in tires; I was getting 7-8 MPG, did a complete tune up, teamrush upgrade and now I average about 13MPG.
h2ojeep is offline
