AMC 304 Idle horrible. - JeepForum.com
post #1 of 14 Old 05-08-2013, 03:04 PM Thread Starter
Jamesromeos
1979 CJ5
I have a question regarding the Idle of my CJ. It has a points 304 in it. The Jeep is idling odd, it is almost as if there is an extreme cam in it, and there is not. going from 400 to 1000 up and down RPM's. I put a full exhaust on it today, and it is still doing the same thing, more pronounced now that I have a complete and semi quiet exhaust. Could this be a result of old technology? I have been saving to put HEI on it, kind of on the back burner with a mortgage and a truck payment. Advice is appreciated.
Jamesromeos is offline
post #2 of 14 Old 05-08-2013, 04:47 PM
davbytrace
1979 CJ7
Perhaps a bad computer or sticking stepper motor in the carb...?
davbytrace is offline
post #3 of 14 Old 05-08-2013, 05:14 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
There is no computer in a '79, unless it was added.
James, what carb are you running, and how long since the last rebuild?
Matt
Matt1981CJ7 is offline
post #4 of 14 Old 05-08-2013, 05:34 PM
82JeepCJ7
1982 CJ7
Just got one for Dad's 72 CJ5 with a 304 in it. $60 off Ebay.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #5 of 14 Old 05-08-2013, 07:30 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
The best thing to do is to start at the beginning.
Clean and adjust the points (dwell)
Check the timing
Insure the firing order is right and the wires are solid
Insure the plugs are good and gapped
Check for manifold leaks including the power brake booster
make sure the choke is off, power valve is good, and adjust the idle mixture
You can check to see if all the cylinders are firing by pulling the wires one at a time. You should get a noticeable RPM drop on every plug
jeepdaddy2000 is offline
post #6 of 14 Old 05-08-2013, 08:12 PM
RDH
I'm thinking about that exact Dizzy...PM me and let me know how it works out for you.
My Holley 4412 was doing the same thing. Adjusted the mixture and the idle screw and everything evened out. Oh, I also had to adjust the float level, was WAY low. Just giving you some starting points.
1978 CJ7: 304, 3Spd, AMC 20 Rear, Thrush Welded Mufflers W/ Turndowns, Unknown Front, Worn out Dana 20 case
RDH is offline
post #7 of 14 Old 05-08-2013, 11:23 PM Thread Starter
Jamesromeos
1979 CJ5
Matt, I am running a 600 edelbrock, it is about a year old, been on this jeep about 2 months. I am leaning toward just doing the HEI anyway...can only improve. How hard is the swap? Just literally swap the distributor and time her?
post #8 of 14 Old 05-09-2013, 12:09 AM
rah2eq
1978 CJ5
My advice is to search high and low for a vacuum leak. Mine was doing the same thing, and it was the combination of vacuum leaks and timing. In my case it was mostly timing, mine was way too far advanced. I'd check these two things; I think a new distributor will almost always help, but in my opinion it shouldn't cause any sort of fluctuation throughout a large RMP range as you stated.
I put in an DUI HEI a few months ago and the installation is painless. I'd warn you to read up on the issues that new distributor gears have caused and I urge you to either swap out your old distributor gear and put it into the new distributor or buy a (hardness) matched set from Bulltear or elsewhere. Otherwise chances are that you'll tear up your cam gear which can quickly destroy your engine.
1978 CJ5 - 304 V8 - Twin Sticked and sitting on 35's
2010 JK- Rock Krawler 2.5" on 35" KM2's
rah2eq is offline
post #9 of 14 Old 05-09-2013, 12:25 AM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
What rah2eq said about the dizzy gear is Gospel. You HAVE to put your old dizz gear on this new unit.
And 82jeepCJ7, Did you do a rebuild w/new cam? If so, I bought mine from skip white and it was a hardened steel gear. Couldn't nick it in my drill press. That new diz gear would have chewed my new Comp Cams' gear right up. I had to put an MSD p/n 8005 $55) iron gear on.
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #10 of 14 Old 05-09-2013, 04:33 AM Thread Starter
Jamesromeos
1979 CJ5
How do the gears come off the distributor? To do both gears do I have to take apRt the timing cover? Would like to avoid that.
post #11 of 14 Old 05-09-2013, 05:00 AM
Matt1981CJ7
1981 CJ7
In my opinion, the surging idle is more likely air, fuel, or vacuum related, not ignition.
The HEI will certainly be an upgrade over points, but don't be surprised if it doesn't cure your problems.
Matt
post #12 of 14 Old 05-09-2013, 07:40 AM
82JeepCJ7
1982 CJ7
I got the HEI from White Performance. I had already planned on swapping the OEM gear onto it. I did the same thing with my HEI. This one is going into Dad's 72 CJ5. I spent the last week rewiring and re-plumbing it.
Swapping gears takes about 5min (4 of that would be looking around my shop for the right punch). Just push out the roll pin, swap dizzy gears, put it back. Done.
post #13 of 14 Old 05-09-2013, 08:20 AM
hutch1200
hutch1200's Avatar
1979 CJ7
No
82 has the skinny on the gear swap.
When he pulls the cap, is it OK just to mark exactly where the rotor is pointing, or should he do it from TDC etc...I always used pinstripe tape straight down the rotor, dizzy and onto the intake or whatever it leads to. Then cut the tape @ the dizzy. Then line the new rotor up w/the tape. Bad practice on my part?
Matts right too. This is just a baby step in the right direction. Be prepared for a less than 100% cure.
post #14 of 14 Old 05-09-2013, 08:45 AM Thread Starter
Jamesromeos
1979 CJ5
I think it is time to go HEI anyway, however I'm going to check timing today as well as vaccum. Is it 5 degrees before tdc? I forget.
