AMC 304 Exhaust Manifold Questions - JeepForum.com
post #1 of 5 Old 11-12-2013, 10:08 AM Thread Starter
lsukevinc
1979 CJ5
I reciently picked up a used set of factory exhaust manifolds for my 79 CJ5 with the AMC 304. The studs were frozen and all four broke off when i tried to remove them. I was able to re tap all of the holes. my first question is should i weld a nut onto the new studs so they fit against the flange of the maniflod (weld nut near the non threaded portion of the stud)? The old studs had a nut in the middle of the stud. Second question is should i paint them or leave them alone? the first picture is similar to the old ones and the second picture is the new ones I bought.
lsukevinc is offline
post #2 of 5 Old 11-13-2013, 10:40 AM Thread Starter
lsukevinc
1979 CJ5
bump
post #3 of 5 Old 11-13-2013, 10:46 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I just used ARP stainless steel manifold bolts on my 360.
They work and look great.
Matt
Matt1981CJ7 is offline
post #4 of 5 Old 11-14-2013, 04:37 PM Thread Starter
lsukevinc
1979 CJ5
should i weld a nut at the non threaded section so i an tighten it against the manifold?
post #5 of 5 Old 11-14-2013, 05:55 PM
82JeepCJ7
1982 CJ7
Put anti-seize on all threads.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
