Amc 304 carb, intake & cam question? - JeepForum.com
post #1 of 18 Old 07-03-2013, 07:33 AM Thread Starter
Gasman303
1979 CJ7
I am thinking about taking off the two barrel carburetor and intake manifold along with all the smog equipment on my 1979 Jeep CJ7 Golden Eagle, 304, 4 speed?!
I'm considering going with a Rochester Quadra jet four barrel 500 CFM carburetor, rv cam and an Edelbrock performer intake manifold along with HEI upgrade and Shorty headers.
This two barrel smog equipped motor just isn't cutting it and this jeep will be my daily driver (15 miles per day) and of course my elk hunting rig.
Has anybody used a Rochester Quadra jet carburetor? I've been reading some good things on this setup up
any suggestions?
Thanks
Gasman303 is offline
post #2 of 18 Old 07-03-2013, 07:39 AM
lsukevinc
1979 CJ5
I have the holley 4 barrel 470 truck avenger, edelbrock performer aluminum intake, edelbrock rv cam, outside of frame headers, and stock dizzy with a MSD box. It runs like a different vehicle now. The response from the accelerator now is like a fuel injected vehicle. I have no regrets.
My father in law lives near castle rock, i love that area.
Last edited by lsukevinc; 07-03-2013 at 07:40 AM. Reason: for got to mention something
lsukevinc is offline
post #3 of 18 Old 07-03-2013, 07:40 AM
big_o_tom
1978 CJ7
Ive heard that they are hard to get adjusted right, but when they are right they are very good carbs. I had an edlebrock performer intake and carb with a set of hedman headers on my 304 and liked it very well.
big_o_tom is offline
post #4 of 18 Old 07-03-2013, 07:53 AM
swatson454
1983 CJ7
Are you going to run headers?
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #5 of 18 Old 07-03-2013, 12:00 PM Thread Starter
Gasman303
1979 CJ7
Yeah, I'm going to run in frame headers! Anyone out there making a Bolt in exhaust system yet for these Cj's?? The muffler shop where I live won't touch any vehicle without Catalac converter?? BS... So I just want to bolt up my own!
post #6 of 18 Old 07-03-2013, 05:14 PM
swatson454
1983 CJ7
I'd suggest these two cams. Those "Edelbrock" cams are actually old Blue Racer grinds from the late 60s, resurrected by Edelbrock's marketing department and ground on old, soft cores that surely won't like todays low ZDDP oil. You'll be down a good amount of torque across the power band vs a modern grind.
http://www.compcams.com/Company/CC/c...x?csid=20&sb=2
http://www.lunatipower.com/Product.aspx?id=1480&gid=287
Hope it helps.
Shawn
post #7 of 18 Old 07-03-2013, 05:44 PM
82JeepCJ7
1982 CJ7
I run an Offenhauser intake and Quadrajet carb. I have never had an issue with the carb on very steep inclines, off camber (laid the Jeep on its side, still running, had to shut it off). I am also running a HEI ignition system. Totally worth it. No more coil and many feet of wiring and old connections to worry about. One wire fed through a relay from the battery for power. Other wire goes to tach. Simple and works great.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #8 of 18 Old 07-03-2013, 05:50 PM
82JeepCJ7
1982 CJ7
Offroad, it just cruises along with no issues.
I built my own exhaust. I used some strait, 45, 90 bends. The ends are from NAPA, made by Walker and bolt right up to the stock manifolds. If your using in frame headers, its even easier.
True dual, no cats.
post #9 of 18 Old 07-03-2013, 09:46 PM Thread Starter
Gasman303
1979 CJ7
http://www.youtube.com/watch?v=KdSwQ-tqVMA
True dual, no cats.
Sick jeep and nice setup you got there!! I thought about getting the 90's and 45's from summit and rigging my own exhaust like you did yours... Awesome
What HEI distributed did you go with and what cfm is you quad? That thing acts and sounds like its fuel injected
jobthanks
post #10 of 18 Old 07-03-2013, 09:52 PM Thread Starter
Gasman303
1979 CJ7
Hope it helps.
Shawn
Thanks for the link's I will look these over!!
I've heard Summits 5600 cam is decent but not good quality of metal used?!! I was thinking more of a RV cam or a grind where I don't have to change valve springs.
post #11 of 18 Old 07-03-2013, 10:51 PM
gwolff
1978 CJ7
Stick with the two barrel. There is a reason Chevy only had a two barrel Rochester on their base 307 69 camaro's. adjust gearing before messing with cfm. A two barrel will scream (especially in a jeep) if gearing is correct.
gwolff is offline
post #12 of 18 Old 07-04-2013, 07:40 AM
82JeepCJ7
1982 CJ7
Almost all Quadrajets are 700 CFM (There are a few 800CFM but they are rare.) Just because its there, does not mean you need to use it. But, I like having that option. The nice thing about a Q-jet is it will only give what the motor needs. The small primary is great for off idle acceleration and mine does not burn a lot of fuel. The secondary's do not open up unless your foot is way in the throttle, so essentially its like a 2bbl with the loud pedal option.
My HEI is just a simple one. You can find them on Ebay for under $100 new. I run one, Dad runs one in his '72 CJ5. The only thing we did was swap out the dizzy gear for the original to ensure the cam gear did not get ate up.
I am into my exhaust for under $200. More if you wanted Flowmasters, but these work just fine. I think they sound OK. Since I built it myself, the whole system is tucked up inside the frame where it will not get damaged (See pic of Jeep on its side). The video was shot just after I laid it on its side. Another thing I like about AMC motors... No holes in the valve covers to leak oil..
post #13 of 18 Old 07-04-2013, 07:45 AM
holliewood61
holliewood61's Avatar
1981 CJ7
I agree. It's hard to beat a properly tuned mc2100. Every experience I've had with a q-jet is that its hard to keep them in tune. Now that may just be the ones I've worked with or something I'm doing. As far as 4 bbl's go, I like edelbrock the best as far as tune it and leave it.
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline
post #14 of 18 Old 07-04-2013, 07:50 AM
82JeepCJ7
1982 CJ7
Edelbrocks are nothing but a paper weight once you get a little off camber. Leave them on street rigs where they belong.
A Q-jet is easy to tune. The biggest item with them is keep them clean. The systems operate on vacuum. In a sense, they are almost self tuning. Set them once, keep them clean, and forget it.
post #15 of 18 Old 07-04-2013, 07:59 AM
RDH
I have a 500 cfm 2bbl Holley on mine. With good tuning I have PLENTY of power and 13 mpg. Saving up to get an HEI next.
1978 CJ7: 304, 3Spd, AMC 20 Rear, Thrush Welded Mufflers W/ Turndowns, Unknown Front, Worn out Dana 20 case
RDH is offline
