Amc 304 Cam Question - JeepForum.com
post #1 of 7 Old 05-06-2013, 07:32 PM Thread Starter
Hbryant123
1979 CJ7
Soon i am going to rebuild my amc 304, its gunna be a for light offroading and pulling my boat a few miles to the ramp, I was thinking of using a cam thats listed for torque, it said good for idle to 4500 rpms, will this cam cause terrible fuel mileage? is it worth my time??
http://www.ebay.com/itm/151025271117...84.m1423.l2649
thats it if anyone wants to check it out
Thanks!!
Hbryant123 is offline
post #2 of 7 Old 05-06-2013, 08:00 PM
swatson454
1983 CJ7
What are you going to run for intake and exhaust?
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #3 of 7 Old 05-06-2013, 08:06 PM Thread Starter
Hbryant123
1979 CJ7
Stock intake and exhaust, i have a holley 4 barrel that came with the jeep
post #4 of 7 Old 05-06-2013, 11:32 PM
DYontheForum
1981 CJ7
The stock intake is gonna restrict the amount of gain you are going to get from a cam.
DYontheForum is offline
post #5 of 7 Old 05-07-2013, 12:50 AM
jumbojeepman
1976 CJ7
I have a Crower Baja Beast camshaft that's for torque, along with a Edelbrock performer intake and carb, stock manifolds. I'm pretty happy with the end result, and my mileage isn't any worse than with the 2bbl carb and stock manifold and cam.
jumbojeepman is offline
post #6 of 7 Old 05-07-2013, 06:48 AM
swatson454
1983 CJ7
Check out the difference between advertised duration, duration at .050 and lift on the ebay cam compared to this Lunati 250/256. The cam you linked appears to be a really old grind and the long advertised duration is going to cut into your mileage, manifold vacuum and low-speed torque pretty bad.
The newer cams hold the valve closed longer, open it quicker and further and get it closed again sooner. This will build more manifold vacuum and power for a given duration at .050 than any of the older style cams. I'm not a big fan of wider lobe separation angles but it will keep reversion at bay with restricted intakes and exhausts and deliver a little better mileage, especially when towing.
I'm guessing that the price is a factor but I really think you'll be much further ahead with a different cam and the one I linked would get my vote for your application.
Shawn
post #7 of 7 Old 05-10-2013, 09:11 PM Thread Starter
Hbryant123
1979 CJ7
What would u recommend for a crank? should i replace the con rods and pistons??
