AMC 258 header question - JeepForum.com
post #1 of 21 Old 10-09-2006, 01:42 PM Thread Starter
AMC Power
Is it ok to run the engine without an exhaust system and just the header? The engine is freshly rebuilt and I need to drive it to get a custom exhaust system installed. Would it be ok to do this or would it hurt the engine?
AMC Power is offline
post #2 of 21 Old 10-09-2006, 02:02 PM
Baloo
Go Tigers!
Baloo's Avatar
1982 CJ7
I don't know if it's harmful or not, but I drove my old 304 CJ5 around town one night with open headers and didn't have any toubles with it afterwards. It was an old engine though, not a freshly rebuilt one. You just have no backpressure running them open. I would trailor it if it's far. You might get pulled over too.
1982 CJ-7
AMC360
4.5" RE 35" X's
Blue Jeep Club Member #1
Baloo is offline
post #3 of 21 Old 10-09-2006, 04:33 PM
CJ7 Vette
make sure you have ear plugs. it will be VERY loud lol.
out of curiuosity, why not just get the rest of the exhaust from one of the catalogs? it just bolts into place....probably cheaper than a custom shop. i put mine in from the header back when swapping motors and it took maybe 20 minutes with the help of a friend.
84 CJ7 new 258,Howell TBI, Borla header/exhaust, clutch, repainted engine compartment,frame and most of undercarriage,jks discos and a host of other new stuff under the hood :)
update: no rust, new floors, stripped, primed, filled, blocked, and repainted with PPG Concept Garnet Metallic. Hardtop freshly painted, all trim painted in black metallic with a bit of flatener mixed in. New seats, carpet, console, roll bar pad, seat belts,dash, flares, windshield, seals, tire carrier and more!
CJ7 Vette is offline
post #4 of 21 Old 10-09-2006, 05:06 PM
BLS33
Chief of the brain police
BLS33's Avatar
the catalog exhaust systems I've come across are pretty expensive, having it done by a shop is usually pretty cheap
As far as driving it to the shop it should be fine
BLS33 is offline
post #5 of 21 Old 10-09-2006, 05:56 PM
Galt
Galt's Avatar
1983 CJ7
Hope like hell you doin't ignite gas fumes from the carb that sits right over top of it and burn your jeep to the ground. I would tow it.
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
1993 RX7 1.3L Rotary/ GT40R turbo/484 rwhp
2002 F-150 Lariat 5.4L V8
2007 GMC Yukon Denali 6.2L V8
Galt is offline
post #6 of 21 Old 10-09-2006, 06:26 PM
BLS33
BLS33's Avatar
I dont understand that theory are you saying running headers runs the risk of igniting gas fumes?
BLS33 is offline
post #7 of 21 Old 10-09-2006, 07:24 PM
Baloo
Go Tigers!
Baloo's Avatar
1982 CJ7
My old 304 would sometimes shoot a small fireball out of the sidepipes. I guess it is possible.
1982 CJ-7
AMC360
4.5" RE 35" X's
Baloo is offline
post #8 of 21 Old 10-09-2006, 09:39 PM Thread Starter
AMC Power
I have the dual outlet header for the 258 and I haven't seen any exhaust systems that keep the dual pipes seperate from each other. I know they sell y-pipes, but I want true dual exhaust. I want my exhaust to exit in front of the rear wheels.
post #9 of 21 Old 10-09-2006, 09:41 PM
Galt
Galt's Avatar
1983 CJ7
You don't understand that the flames that can most definitely shoot out of a header can ignite gas fumes? I blow flames out the *** of my RX7 all the time. Thats all the way through a down pipe, a mid pipe with a borla welded in and then through a catback. I am certain I could get some out flame of a header all of 15" long. If you want to drive with an open exhaust then have at it. I would advise against it.
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
Galt is offline
post #10 of 21 Old 10-09-2006, 09:57 PM
BLS33
BLS33's Avatar
The end of the header is really not too close to the the carb or where any gas fumes are.
I've driven trucks around with open headers a ton of times just to move them from place to place and have yet to be ungulfed in a fireball. It just doesnt seem like a very big risk at all, and I'm speaking from experience. I dont get how flames coming from the end of a header could possibly ignite any fumes.
BLS33 is offline
post #11 of 21 Old 10-09-2006, 11:09 PM
CJ7 Vette
cool!
post #12 of 21 Old 10-10-2006, 12:04 PM
hfjeff
hfjeff's Avatar
I test drove my fresh 360 about 10 miles with open headers in 97 degree weather with no engine issues. However it was LOUD! So loud that I could not hear that my starter solenoid was stuck and it fried my starter. (The starter gear was mashed over like a mushroom. Luckily it did not damage the flywheel ring gear.) I also drove it to the custom muffler shop a few days later. I was more concerned about getting a ticket than anything else, especially since I live a few houses away from a County Cop.
MINE: 1995 YJ/2.5L/115K/Completely Stock
MY DAD's: 1978 CJ7/ AMC 360 .030" over/ Motorcraft 2100/ Edelbrock Performer/ Proform HEI Ignition/ Hedman Headers with dual Flowmaster 40's/ Taurus Fan/ FK-35 Control/ Painless Harness/ Rebuilt T150 & Dana 20/ 4" Lift/ 31" Procomp Mud Terrains/ All Fiberglass. (SOLD)
MY BROTHER's: 1996 ZJ Limited/5.2L/117K & Completely Stock.(SOLD)
hfjeff is offline
post #13 of 21 Old 08-29-2010, 05:36 PM
IDK
X2 on loudness! Back when my Bronco had headers 2 of the collector bolts fell off and the exhaust pipe was held on by one bolt and it exposed the collector opening and that was unbearably loud! I couldn't imagine it with no exhaust at all! But I got sick of the headers and put manifolds on it so I would have some ground clearance, did away with the old rusty exhaust pipes and straight piped it, now it sounds perfect to my ears anyway, the tree hugger neighbors hate me though!
JpThang
IDK is offline
post #14 of 21 Old 08-29-2010, 06:04 PM
Eaglekeeper
When you get the pipes done, please post some pics. I' haven't decided on single or dual outlets and like to see how yours come out. Any clearance problems with the duals? Thanks
86 CJ7, 258 Engine, T-177, Dana 300.
A ton more pics here.
Eaglekeeper is offline
post #15 of 21 Old 08-29-2010, 06:36 PM
CT84CJ7
backpressure
I have heard that exhaust provides backpressure that helps the engine rings seat with a new engine. I think you would be fine, I would not drive a long distance. Also something that I would do is slow easy acceleration then let off with and keep in gear for a slow down that will help the seating of the rings. Just once or twice and nothing extreme.
CT's 84 CJ7
CT84CJ7 is offline
Header Question jpfaris Jeep CJ Forum 5 04-23-2007 12:46 PM
Header question medunwoody Jeep CJ Forum 6 11-17-2006 10:27 PM
Header Question... jason43 Jeep CJ Forum 3 05-08-2006 06:56 AM
Header Question Lethl_SS Jeep CJ Forum 4 01-29-2006 07:22 PM
Header Question for a 304 V8 FireMedic Jeep CJ Forum 5 07-05-2003 08:52 PM
