AMC 258 Fuel Injection - JeepForum.com
post #1 of 9 Old 02-20-2007, 05:47 PM Thread Starter
AMC Power
Can you use the stock 4.2 head with fuel injection or do you have to do the 4.0 head swap?
AMC Power is offline
post #2 of 9 Old 02-20-2007, 07:27 PM
gt4660
1992 XJ Cherokee
Two words, Howell Injection... Easy install ,runs great!
gt4660 is offline
post #3 of 9 Old 02-20-2007, 07:58 PM
Rob55
Fi
I have the Hesco (Mopar) kit with the 4.2 head. It can be used either way but the manifolds must be matched to the kit you buy. I have heard good things about the Howell, but the Multi port is a little more efficient (and expensive) than the Howell TBI. It is huge advantage at altitude and big angles that challenge carbs.
1984 CJ7, 258, MPI, 4.0 head, Borla, 700r4, amc20 (detroit), Dana 30 (OX), 4.56 gears, Warn Hubs, Dana 300 with 4:1, 4.5 RE lift with 1" body, Bilsteins, dual battery, PS, PB, full cage, two dogs in the back....
Rob55 is offline
post #4 of 9 Old 02-20-2007, 08:02 PM
gojeepin
1983 CJ7
The Howell kit is a throttle body fuel injection kit. It mounts to the intake manifold much like a carb. No need to replace the intake manifold... nothing but the carb.
It's a pressurized fuel system unlike the carb... no float or venturi. It's the simplest way to inject your engine.
The kit is very complete. It has the computer, wiring harness... all you need to hook it up.
gojeepin is offline
post #5 of 9 Old 02-20-2007, 08:26 PM
nichols077
im also looking into fuel injection, but dont want to spend more on it than i did on my jeep. haha.
nichols077 is offline
post #6 of 9 Old 02-20-2007, 09:07 PM
ClarkGriswold
ClarkGriswold's Avatar
Does anyone know the approx cost of the Howell kit and where to find it? Part number, etc? Does it provide any additional HP?
If I was changing my Carter carb - what would be best?...the Howell throttle body or a Weber or Motorcraft carb?
"That's nothing to be proud of Rusty. .....fifty yards." - Clark Griswold
Red Jeep Club #488
ClarkGriswold is offline
post #7 of 9 Old 02-20-2007, 09:20 PM
jeepin in maine
if your interested in building your own,research doing the gm throttle body swap before you dump big $$.i think thats the route i'm going to go.heres some info i found that initially got me interested in this idea.
http://www.jeepforum.com/forum/f8/totw-fuel-injection-229253/
http://www.binderbulletin.org/forums...ad.php?t=47254
http://www.bustedjeep.com/projects/gmtbi.asp
jeepin in maine is offline
post #8 of 9 Old 02-20-2007, 09:25 PM
Rob55
Fi
The Howell kit is on ebay for aout $1145 from Collins. The off road only kit is a little less.
http://cgi.ebay.com/ebaymotors/HOWEL...spagenameZWD1V
The MPI kit is available at Hesco, for about $2300.
http://www.hesco.us/shop.asp?action=...025&catId=7577
Hesco is rated at higher horsepower, and has a few aftermarket parts to boost it further. Both are a better choice (in my opinion) than carb...although FI is more complicated to troubleshoot on the trail if your not familiar with it.
FI should increase gas mileage (over a carb) as well.
Rob55 is offline
post #9 of 9 Old 02-21-2007, 12:30 AM
BIGM
www.sierrajeep.com has a good comparison of the two FI kits.
BIGM is offline
CJ Fuel Injection? smitty586 Jeep CJ Forum 32 03-17-2014 12:12 AM
Fuel Sending Unit and Fuel Injection Question CJman77 Jeep CJ Forum 4 12-21-2009 05:01 PM
Fuel Injection lycowarrior Jeep CJ Forum 3 09-17-2005 10:34 AM
fuel injection on 258 supersly_jones Jeep CJ Forum 2 07-27-2004 09:09 AM
258 Fuel Injection? skirider Jeep CJ Forum 15 11-10-2002 10:57 PM
