Amc 258 - JeepForum.com
post #1 of 33 Old 07-26-2013, 09:05 PM Thread Starter
Cpolinsky
Amc 258
Quick question, will a t-5 hold up to a amc 258? I have a t-5 to a amc 151 and have a chance to get a 258. I know there are other transmission that are better (I have a t176 w/360 in storage that both need to be rebuild but storage unit is 2 states away). But I'd like to still keep it manual and if I can make it work great if not any suggestion for a 258 that I could find (manual still) that will work with my dana 300.
Thanks, Chris
Cpolinsky is offline
post #2 of 33 Old 07-26-2013, 09:08 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
I ran my T5 for a couple of years behind my 258,,,Wasn't the best, but it did work! Just don't abuse it and you should be fine!
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #3 of 33 Old 07-26-2013, 09:37 PM
BagusJeep
1981 CJ7
A 258 is not a stump puller but is a "lightweight, furl efficient engine" according to AMC in the day.
The T5 can handle the power and torque from the lump. However it is a relatively long light car transmission, hence it does not stand up very well to the abuse of serious offroading.
There are better choices out there but if it is surviving in your Jeep already then it will probably continue to do so.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 33 Old 07-26-2013, 10:28 PM
billybooster2
1983 CJ8
I have a t5 and 258 (now with EFI as well) AND 4:1 D300 gears and it works fine on finessed offroading trips. I doubt serious burn outs or mud would be good for it... but crawling its held up 30 years so far.....
billybooster2 is offline
post #5 of 33 Old 07-26-2013, 11:57 PM
Jeep-N-0311
Just a thought - have you done a search (ebay, craigslist, local sale magazines at the 7-11, etc) for a T-176 locally? chances are you might find a few (including some that don't need rebuild, possibly already connected to a D300, bellhousing, linkage, etc) for sale for a reasonable price. I wanted to get rid of my rattly old T5; I found a T176 w/D300 (and clocking ring mounted) & bellhousing for like ... $300.
Jeep-N-0311 is offline
post #6 of 33 Old 07-27-2013, 01:01 AM Thread Starter
Cpolinsky
This wouldn't be any serious off roading. Basically I have a chance to get a 258 and would love to upgrade from the 151. I just have been reading mixed reviews about that match up. Eventually I'll replace both down the road with a 176 and 360. If I had access to them know I'd just start rebuilding them but I can't for a while. (thankfully I can pay my storage unit online).
Billybooster It wouldn't be for burn outs of any kind. Just an upgrade from what I have now. Did you swap out for the 258 or was it already there when you go it?
I'm just wondering what I'm going to need to do (new radiator, starter, alt, probably carb rebuild, different exhaust). Would I just cut the exhaust where it meets the old intake and then get that welded back. I don't know how to weld so I'd probably to go to either a muffler or welder to do it for me. Would I need new motor mounts? Or will the same ones work? I did replace them when the engine was pulled a few yrs ago.
Any other things I should know about before tackling this (problem areas what to expect or should this be pretty easy)?
post #7 of 33 Old 07-27-2013, 07:00 AM
billybooster2
1983 CJ8
Any other things I should know about before tackling this (problem areas what to expect or should this be pretty easy)?[/QUOTE]
It was original 258 t5 factory. As long as u dont abuse it itll hold up fine to a 258
post #8 of 33 Old 07-27-2013, 10:22 AM
LumpyGrits
The reason the T-5 didn't hold up real well in CJ's was 1, the STUPID hi R&P's the were used by AMC(2:73). 2, then folks would put 33"+ tires on, and all the torque load went on the tranny(bad)and not the R&P(where it should be)
I have run a T-5 for 28+ years. Don't drive stupid and you should be fine.
I do run 4:88 R&P.
LG
LumpyGrits is offline
post #9 of 33 Old 07-27-2013, 10:35 AM
billybooster2
1983 CJ8
I agree with LG. im running 456 and 35's..
post #10 of 33 Old 07-27-2013, 10:38 AM Thread Starter
Cpolinsky
Thanks everyone now just can't wait to do this.
post #11 of 33 Old 07-27-2013, 10:45 AM
LumpyGrits
You would do good to install Moser 1-piece axles too.
Moser's are the best choice for this.
Good luck,
LG
post #12 of 33 Old 07-27-2013, 10:52 AM
titomars
1981 CJ7
I do run 4:88 R&P.
LG
I pumped up my 258 alot. I also do burnouts quite a bit. I have 4:10s and lockers on 33X12.50s. There is not a thing wrong with my T-5. It takes it fine.
Remember in the 80's these things were used in Mustang GT's, Camaro Z28's and Firebird T/A's with engines up to 350 ci and over 300 HP. I also used one in an F150 stepside. That was producing 332 HP with a 300 I6 that regularly spun up to 7500+ rpm which I used to street race all the time. That being said they are not built for off roading they are/were street 5 speeds. As everyone says don't be stupid with it and it will hold up fine.
On another note the 4cyl version is a bit different than the 6cyl version.
gear ratios are different and the input shaft is different. ratios would not be a problem but the input will require you to use different clutch pieces over stock to make it work. I am pretty sure the bell housing is different too. Motor mount brackets are different. I would assume the radiator is also different. The Hydraulic clutch linkage is easy to adapt.
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #13 of 33 Old 07-27-2013, 11:22 AM
LumpyGrits
The T-5 in our Jeep's and the T-5 used in the Mustang, et-al, are no ways near the same 'box'. They never have been either
LG
post #14 of 33 Old 07-27-2013, 11:42 AM
titomars
1981 CJ7
LG
Actually they were. The "World Class" box did not come out till 85/86 and that is different internally. Other than ratios there was no internal differences between the Jeep, S-10, Ford or any other T-5 from 82 to 84/85. besides the obvious input shaft and retainer and main shaft and tail housing. Even the Jeep main case is exactly the same as the Ford main case. The only difference is AMC did not migrate to the world class box when everyone else did.
titomars is offline
post #15 of 33 Old 07-27-2013, 11:59 AM Thread Starter
Cpolinsky
I forgot about the bell housing what would I need to do to make it work to a t5 I thought they were different? (Any mods I have to make to make it fit)
