amc 20 yoke play - JeepForum.com
post #1 of 4 Old 02-05-2013, 04:24 PM Thread Starter
MichaeljR
1981 CJ7
amc 20 yoke play
the pinion seal on my amc 20 is leaking, so i'm about to replace it .i got the cover off, oil drained, u-joint disconnected from the yoke.i can't remove pinion nut till tomorrow(i have to drive an hour to oreilly's to get a 1 1/8'' socket).i noticed the yoke has about a 1/16" of play side to side and up and down.is this normal or should i plan on replacing the outer pinion bearing as well?
MichaeljR is offline
post #2 of 4 Old 02-05-2013, 04:33 PM
hp_lovecraft
1981 CJ5
Keep in mind that changing that bearing requires removing the entire carrier, and pulling the axles. and its a fairly involved process to get it all together, involing crush sleeves, and special tools.
Note: My yoke had a bit of play as well, but after I changed the seal, and torqued it back up, the play went away, so who knows. Changing the seal itself is a much easier task, though since you would be reusing the same crush sleeve, its hard to tell if you are setting the proper preload.
hp_lovecraft is offline
post #3 of 4 Old 02-05-2013, 04:43 PM Thread Starter
MichaeljR
1981 CJ7
"ya,i'm hoping the new seal will help with the play.it's worn pretty bad. thanks for the reply.
post #4 of 4 Old 02-05-2013, 05:27 PM
82JeepCJ7
1982 CJ7
BTW, the nut is 1-5/16" and the socket usually has to be turned down on the outside to fit into the yolk.
Just wanted to save ya a trip.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
