amc 20 trusses let's see them - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > amc 20 trusses let's see them
Yukon Ultimate 35 axle kit for c/clip axles with Yukon ZipNitro Gear Packages Now Available at Rockridge 4wdSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREE
Unread 06-27-2009, 01:57 PM   #1
trailridin4x4x4
1981 CJ7
looking to truss my amc 20 soon, so i'd kinda like to see what everybody has done.....thanks
trailridin4x4x4 is offline   Reply With Quote Quick reply to this message
Unread 06-27-2009, 02:50 PM   #2
gojeepin
1983 CJ7
BESRK made mine... I think he makes a You-weld-it kit.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline   Reply With Quote Quick reply to this message
Unread 06-27-2009, 02:58 PM   #3
jeepmor
I gutted my old bent tubes and had 3/8 wall DOM tubing installed. I had a shop do it, $500 total, and I brought the rear in gutted of all but the gearing.
I did this as I already had bent tubes. I also have the low gears, detroit locker and warn full floater in it already, so it was cheaper route than a new housing workover. Jeep ran great with 33's, but when I went to 35" tires, they bent after some hard wheeling and my rear wheels were no longer parallel to each other. Looked funny.
If your tubes are bent, I'd gut it as I did. If not, then a brace is a sound investment.
jeepmor is offline   Reply With Quote Quick reply to this message
Unread 06-27-2009, 05:36 PM   #4
trailridin4x4x4
1981 CJ7
tubes aren't bent but i want truss it so i don't have that problem just want to know what's out there
Unread 06-27-2009, 07:32 PM   #5
ken78cj5
1978 CJ5
I used some 2X8 1/8"wall square tube. Used some manila file folders to make the scalloped shape and welded it. I can get ya a pic tomorrow. I would also recommend welding the joint betweent he housing and the tubes. Keeps them from rotating.
Ken
ken78cj5 is offline   Reply With Quote Quick reply to this message
Unread 06-27-2009, 08:50 PM   #6
trailridin4x4x4
1981 CJ7
tubes are already welded to the diff by the previous owner
Unread 06-27-2009, 08:56 PM   #7
berserker
Check out this thread for some ideas: http://www.jeepforum.com/forum/showt...+20+axle+truss
Ignorance can be fixed, but stupidity is forever.
berserker is offline   Reply With Quote Quick reply to this message
Unread 06-27-2009, 09:04 PM   #8
trailridin4x4x4
1981 CJ7
cool thanks erik
Unread 06-28-2009, 08:35 AM   #9
gojeepin
1983 CJ7
The link provided by berserker above includes my axle as it was being built... Here's the completed axle.
