AMC 20 Truss - JeepForum.com
post #1 of 21 Old 03-10-2013, 11:07 PM Thread Starter
RedCJ83
1983 CJ7
AMC 20 Truss
Spun the diff on the tubes a while back, cut the spring perches, ran a bead around the tubes, put a support bracket on the center diff sides, built/installed a truss across top, realigned the driveshaft and rewelded purches.
RedCJ83 is offline
post #2 of 21 Old 03-10-2013, 11:13 PM Thread Starter
RedCJ83
1983 CJ7
Pic
Support bracket
RedCJ83 is offline
post #3 of 21 Old 03-10-2013, 11:14 PM Thread Starter
RedCJ83
1983 CJ7
Pic
Truss is above, not support bracket....loaded. Wrong pic
RedCJ83 is offline
post #4 of 21 Old 03-10-2013, 11:18 PM Thread Starter
RedCJ83
1983 CJ7
Pic 2
Support Bracket
RedCJ83 is offline
post #5 of 21 Old 03-11-2013, 12:15 PM
Renegade82
1982 CJ7
I just had a truss welded to mine and the tubes welded also. Mine had 2 plug welds on each side (above and below the diff. spreader holes) that were welded from the factory. Did your have them?
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #6 of 21 Old 03-11-2013, 02:18 PM Thread Starter
RedCJ83
1983 CJ7
Yes, great looking truss.
RedCJ83 is offline
post #7 of 21 Old 05-20-2014, 09:36 PM
Newbjeep
1972 CJ5
Deleted
Newbjeep is offline
post #8 of 21 Old 05-20-2014, 09:37 PM
Newbjeep
1972 CJ5
I know this is an old thread but its on topic. would 10 gauge metal be thick enough to do this with? I can get it free so id like to use it
P.s. its for my brother in-laws cj7
Newbjeep is offline
post #9 of 21 Old 05-21-2014, 12:26 PM
Newbjeep
1972 CJ5
Anyone?
Newbjeep is offline
post #10 of 21 Old 05-21-2014, 02:11 PM
dirtdudeaz
1983 CJ7
Unless anyone on here has access to Ansys, I don't think you can say positively. It all depends on where and how you use it (That's what she said)... You can resarch what other peoiple have used, but I am not sure you will get a response that tells you to use it without any backing...
The axles I have seen (4 or 5 in the last 2 months) that were bent, had bent just outside the perches. These jeeps had 31"-35" tires on them, and did light to moderate trail and desert running. Personally, I like to see the truss extend out to the axles tubes where the tubes flange out to cover the type of bending I described.
Right now, I am using an 1-3/4 .120 DOM tube bent in the middle to span over the pumpkin and out to the flanges. Then I am using 1/4 plate and tying in the ends of the tube to the axle tubes, and the middle of the tube to the main part of the pumpkin. In the middle I am using 1 side of plate, and on the ends possibly 2 to sandwhich the DOM tube in.
dirtdudeaz is offline
post #11 of 21 Old 05-21-2014, 03:12 PM
Newbjeep
1972 CJ5
He is running 35s my plan was to make basically a c channel that is shaped to his axle and end right around where it flares out at the end of the axle housing
Newbjeep is offline
post #12 of 21 Old 05-21-2014, 03:49 PM
Renegade82
1982 CJ7
Newbjeep - I wouldn't consider it. Most I've seen were at least 3/16" and thicker. Mine is made from 5/16" and then doubled across the top 1".
Dirtdude - I agree that a better truss would be out to the flanges where impact loads would be the greatest. My original plan was to do that but it got changed once the time came to do it.
post #13 of 21 Old 05-21-2014, 04:27 PM
Newbjeep
1972 CJ5
Ya im gonna tell him I can't do it cause I don't have the metal. Is there a kit out there for the offset 20?
Newbjeep is offline
post #14 of 21 Old 05-21-2014, 04:29 PM
dirtdudeaz
1983 CJ7
I didn't find any kits out there. There was a member on here who has an ebay fab store that used to do them. I tried PM'ing him a while back and never heard anything. Maybe you could try...
post #15 of 21 Old 05-21-2014, 04:33 PM
Newbjeep
1972 CJ5
I think ill have him go to a shop he knows of that could probably do it for him thanks for the responses
Newbjeep is offline
