AMC 20 rear pinion seal, torque value, not again - JeepForum.com
post #1 of 5 Old 08-15-2009, 03:50 PM Thread Starter
jetamerica
85 CJ7, 2012 Wrangler
jetamerica's Avatar
Thanks to everyone for their help, the search on the pinion seal was very helpful. When I went to check the torgue value to turn the rear pinion assy prior to removing the pinion nut, tires and brake drums off, I was expecting about 20 inch pounds or so. Mine barely read anything, less then 5 inch pounds to turn the assy. I have had no problems in two years of owning this jeep. After I replace the seal should I tighten the pinion nut until it takes 10 inch pounds (the original 5 Inch pounds to turn the assy plus an additional 5 inch ponds) or should I tighten the pinion nut to a specific minimun torque value to turn the pinion assy. thanks and sorry for another pinion seal question.
1985 CJ AMC 20 rear with factory 3.31 gears, T-5, 6 cyl
If anyone has a honey denim seat in any condition from this era I am looking
jetamerica is offline
post #2 of 5 Old 08-15-2009, 04:59 PM
rixcj
rixcj's Avatar
1979 CJ5
I'm no expert, but it sounds like that will work for you.
I just did the same thing, but my reading was 14 in./lbs. initially, so I re-tightened to 19 in./lbs.with a new seal in.
Hopefully, others will chime in.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #3 of 5 Old 08-15-2009, 06:19 PM Thread Starter
jetamerica
jetamerica's Avatar
rixcj,
I don't have the tools to make the tool to hold the yoke when I loosen the pinion nut, what did you use or did you make one.
post #4 of 5 Old 08-15-2009, 07:14 PM
NelsonATC
1980 CJ7
Used a large pipe wrench when I did mine. Worked great!
Mike
1980 CJ7
NelsonATC is offline
post #5 of 5 Old 08-15-2009, 09:54 PM
rixcj
rixcj's Avatar
1979 CJ5
Originally Posted by jetamerica View Post
rixcj,
Yes. I made a yoke holder tool, several years ago. After the new seal was installed, I used an impact gun to get the new pinion nut close to touching the yoke, then, from there on , I used a ratchet the rest of the way.
I did VERY SMALL increments. Tighten a little, check torque. Tighten a little more, check the torque, again.
I followed this procedure until I was at 19 in./lbs, which was my target number.
I had to use the yoke holder throughout the entire nut tightening process.
Here are a few pics of it...
Rich
rixcj is offline
AMC 20 Pinion Rotation Torque (seal replacement) 243 Jeep CJ Forum 8 10-18-2009 07:55 PM
AMC 20 Pinion Nut Torque CherryCj7 Jeep CJ Forum 13 07-25-2009 08:22 PM
how much D60 pinion nut torque junglejeep Jeep CJ Forum 6 06-18-2006 09:54 PM
rear pinion seal wm69 Jeep CJ Forum 1 05-06-2004 07:37 AM
Model 30 front axle and model 20 rear pinion oil seal? Paul M Jeep CJ Forum 6 06-08-2003 07:33 AM
