AMC 20 Rear Axle Nut size?? - JeepForum.com
post #1 of 15 Old 06-18-2013, 06:02 AM Thread Starter
BeesJeep
1981 CJ7
I am in the process of putting new bearings in my rear axle and I need to tighten down the large nut with a pin that holds the hub to the axle. My issue is that a 1 1/14 socket is a little too small. I can get it on but I have to use a hammer and it messes up the edges of the nut. A 1 3/8 seems a little too big. Is the correct size 1 5/16? And, if so, do they even make a socket this size?
BeesJeep is offline
post #2 of 15 Old 06-18-2013, 07:40 AM
CJ7ROB
I believe it is 32 or 33mm.
CJ7ROB is offline
post #3 of 15 Old 06-18-2013, 07:57 AM
CSP
Yes, there is a 1-5/16". I have this size in 1/2" and 3/4" drives.
CSP is offline
post #4 of 15 Old 06-18-2013, 12:54 PM
LumpyGrits
YUP
LG
LumpyGrits is offline
post #5 of 15 Old 06-18-2013, 01:09 PM
82JeepCJ7
1982 CJ7
Just so happens, the pinion nut on the AMC 20 axle is 1-5/16" as well.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #6 of 15 Old 06-18-2013, 01:42 PM
keith460
Jeep. There's Only One
keith460's Avatar
Its ironic, but the measurement from the end of the axle threads where the nut screws on-to-the wheel hub is also set to 1-5/16" or 33mm.
1984 CJ-7 Renegade
keith460 is offline
post #7 of 15 Old 06-18-2013, 06:27 PM Thread Starter
BeesJeep
1981 CJ7
Which company makes a 1 5/16 socket? I checked Sears (Craftsman) and they didn't have one.
BeesJeep is offline
post #8 of 15 Old 06-18-2013, 06:31 PM
skizriz
1978 CJ7
I picked up a 3/4 drive socket at Tractor Supply for about $5.
skizriz is offline
post #9 of 15 Old 06-18-2013, 08:35 PM
LumpyGrits
Sears sure does......
http://www.sears.com/craftsman-1-5-1..._tnt=39869:4:0
Snap-on, Proto, Maco also have them
LG
post #10 of 15 Old 06-18-2013, 08:42 PM
CSP
The Sears you checked not having one in stock doesn't mean that Crapsman doesn't make one. My 3/4" drive 1-5/16" is part of a Craftsman set. I have that size in 1/2" from Armstrong, Proto, and Snappy.
CSP is offline
post #11 of 15 Old 06-19-2013, 06:47 AM
CJ7ROB
Then there's HF...Probably worth though it for as many times as you'll use a socket that big.
http://www.harborfreight.com/8-piece...set-67960.html
CJ7ROB is offline
post #12 of 15 Old 06-19-2013, 10:38 AM
82JeepCJ7
1982 CJ7
The outside of the socket has to be turned down to a bevel to fit into the yoke on the rear axle (if your using it for that) so a harbor freight socket might be worth it.
post #13 of 15 Old 06-20-2013, 06:56 PM Thread Starter
BeesJeep
1981 CJ7
I ended up getting the 3/4 drive socet from Tractor Supply for $7 with a 3/4 to 1/2 adapter for another $5. That was a pretty good deal! thanks for the advice!
BeesJeep is offline
post #14 of 15 Old 06-20-2013, 07:02 PM
skizriz
1978 CJ7
I would go with a 3/4 breaker bar over a 1/2 drive. No way will a 1/2 drive get it tight enough.
Put about a 4' piece of pipe on a 3/4 drive breaker bar, stand on it and jump up and down until it doesn't move.
Drive a few miles and do it again. And again, until you can't budge it any more.
skizriz is offline
post #15 of 15 Old 06-21-2013, 12:26 AM
BagusJeep
1981 CJ7
if I recall I had a 33mm 3/4" drive socket as most 1/2" drive sets are max 32mm. I then purchased a very nice Japanese made 3/4" drive bar and literally jumped up and down on the end to get the required torque. It goes on real tight so no half measures, and you will possibly bend a 1/2" drive on it if you torque it enough.
Like the 36" Stillsons pipe wrench it was something I did not think I needed for the CJ until I got it.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
