-   -   AMC 20 Rear Axle Nut size?? (http://www.jeepforum.com/forum/f8/amc-20-rear-axle-nut-size-1538000/)
BeesJeep 06-18-2013 07:02 AM
I am in the process of putting new bearings in my rear axle and I need to tighten down the large nut with a pin that holds the hub to the axle. My issue is that a 1 1/14 socket is a little too small. I can get it on but I have to use a hammer and it messes up the edges of the nut. A 1 3/8 seems a little too big. Is the correct size 1 5/16? And, if so, do they even make a socket this size?
CJ7ROB 06-18-2013 08:40 AM
I believe it is 32 or 33mm.
CSP 06-18-2013 08:57 AM
Yes, there is a 1-5/16". I have this size in 1/2" and 3/4" drives.
LumpyGrits 06-18-2013 01:54 PM
YUP:thumbsup:
LG
82JeepCJ7 06-18-2013 02:09 PM
Just so happens, the pinion nut on the AMC 20 axle is 1-5/16" as well.
keith460 06-18-2013 02:42 PM
Its ironic, but the measurement from the end of the axle threads where the nut screws on-to-the wheel hub is also set to 1-5/16" or 33mm.
BeesJeep 06-18-2013 07:27 PM
Which company makes a 1 5/16 socket? I checked Sears (Craftsman) and they didn't have one.
skizriz 06-18-2013 07:31 PM
I picked up a 3/4 drive socket at Tractor Supply for about $5.
LumpyGrits 06-18-2013 09:35 PM
Sears sure does......:rolleyes:
http://www.sears.com/craftsman-1-5-1..._tnt=39869:4:0
Snap-on, Proto, Maco also have them
LG
CSP 06-18-2013 09:42 PM
The Sears you checked not having one in stock doesn't mean that Crapsman doesn't make one. ;) My 3/4" drive 1-5/16" is part of a Craftsman set. I have that size in 1/2" from Armstrong, Proto, and Snappy.
CJ7ROB 06-19-2013 07:47 AM
Then there's HF:D...Probably worth though it for as many times as you'll use a socket that big.
http://www.harborfreight.com/8-piece...set-67960.html
82JeepCJ7 06-19-2013 11:38 AM
The outside of the socket has to be turned down to a bevel to fit into the yoke on the rear axle (if your using it for that) so a harbor freight socket might be worth it.
BeesJeep 06-20-2013 07:56 PM
I ended up getting the 3/4 drive socet from Tractor Supply for $7 with a 3/4 to 1/2 adapter for another $5. That was a pretty good deal! thanks for the advice!
skizriz 06-20-2013 08:02 PM
I would go with a 3/4 breaker bar over a 1/2 drive. No way will a 1/2 drive get it tight enough.
Put about a 4' piece of pipe on a 3/4 drive breaker bar, stand on it and jump up and down until it doesn't move.
Drive a few miles and do it again. And again, until you can't budge it any more.:cheers2:
BagusJeep 06-21-2013 01:26 AM
if I recall I had a 33mm 3/4" drive socket as most 1/2" drive sets are max 32mm. I then purchased a very nice Japanese made 3/4" drive bar and literally jumped up and down on the end to get the required torque. It goes on real tight so no half measures, and you will possibly bend a 1/2" drive on it if you torque it enough.
Like the 36" Stillsons pipe wrench it was something I did not think I needed for the CJ until I got it.
The time now is 10:19 PM.
